Old 03-10-2016, 04:26 PM   #1
ubtripn
ubtripn's Avatar
Who runs ethanol gas?
I have two stations in Boise selling non-ethanol. Its all I use since I put my crate motor in. Around here we have E10. What I was told was that means 90% gas and 10% ethanol.
Now the E85 - I was told it is 15% gas and 85% ethanol. That must be wrong.
In any case, since gas prices are down so low I am driving my truck everywhere (talk about a great time for all with classics) but I think I need to upgrade gaskets and fuel hoses to run even E10. Some said I don't have to but my Husqvarna lawnmower developed crystals off E10 that I had to remove then it ran fine again.
Does anybody just run the E10? Have you had issues? Sorry in advance if this is a sore topic.
ubtripn is offline   Reply With Quote
Old 03-10-2016, 04:47 PM   #2
gvnick
Re: Who runs ethanol gas?
Here in California E10 is all we can get. It will be fine to run without changing anything, you will notice a slight loss of power and slightly worse MPG.
E10 does go bad when stored longer than a month, so add stabilizer if the truck sits during the winter.
I'd go out of my way to buy 100% gas personally.
69 GMC shortbed
Carbed LM4 - Manual VB TH350 - Gear Vendors OD
gvnick is offline   Reply With Quote
Old 03-10-2016, 05:25 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Just replace any rubber lines with a hard line (I recommend that anyway!). You can use the rubber lines with the fuel filter along the frame rail, etc, as long as you swap filters every few years with new rubber lines you'll be fine.
They imposed the year round E10 (used to be winter only) thing like 7 or 8 years ago here and I've been running it in my truck with no issues yet. I pulled the carb not too long ago and it was pretty clean inside.
It doesn't cause issues for lawn equipment if you use the stabil thats meant for E10, especially if it's going to sit over the winter or for more than a few weeks.
I'd like to run the 100% stuff, but they charge 50 cents more per gallon no matter what the price of fuel is.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-10-2016, 06:15 PM   #4
ubtripn
ubtripn's Avatar
Yeah its about 25$ more here. Thanks all.
Old 03-10-2016, 06:42 PM   #5
truckster
truckster's Avatar
Nope, it's not wrong. E85 is 85% ethanol. It should only be used in vehicles that are built for it - they're usually labeled flex fuel.
But... if you have a sniffer-type emissions test where you live, and your vehicle is having a hard time passing, E85 does burn cleaner and may just be what you need to pass the emissions test.
truckster is offline   Reply With Quote
Old 03-10-2016, 07:21 PM   #6
Custom/20
Custom/20's Avatar
Up here in Washington there's a couple stations that I could go to for ethanol free gas but are to far away for me to bother with so I only use Chevron gas. It may have 10% ethanol but I don't let the engine sit for a month at a time so I'm not really worried about it.
Custom/20 is offline   Reply With Quote
Old 03-10-2016, 07:43 PM   #7
swamp rat
swamp rat's Avatar
I run Ethanol free in my rat because its not my daily driver and ethanol plays havoc on my carb if not run at least weekly.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-10-2016, 08:41 PM   #8
1968aj
I wish I could get ethanol free. none any where near Houston that I know of.
1968aj is offline   Reply With Quote
Old 03-10-2016, 08:45 PM   #9
68Stepper
E85 is a corrosive fuel because of it's alcohol content. The fuel system will have to be upgraded to handle the fuel. Also just a side note, you can make much more power on E85 than pump gas but you'll also lose roughly 15% fuel economy...
After upgrading the fuel system, your timing will have to be advanced and motor retuned
68Stepper is offline   Reply With Quote
Old 03-13-2016, 08:00 PM   #10
chefk85
chefk85's Avatar
We have 2 stations here. 1 in Hailey. 1 in Bellevue that sell non ethanol but they charge so much more that by the time the ethanol did gum up your carb(if it ever did. I run 85 octane E10 with no problems yet) you would be able to buy a brand new one! Just don't leave it sitting for months unless the tank is full or you have additives as ethanol attracts water and engines don't like to run on H2o. We need to start an Idaho truck club where we can get together and share/trade skills to help each other with projects.
chefk85 is offline   Reply With Quote
Old 03-13-2016, 08:20 PM   #11
In The Ten Ring
Easy with these questions! I asked about storing gas on here last year and the thread ended up attracting a lot of hot heads, upset over govt control (and rightfully so), but somehow angry with me that my mower doesn't have trouble starting after sitting all winter with E 85.
I would think we'll all have to run ethanol-mix unless we tow a tank of non-mix with us. I don't like mixed gasoline, I don't like govt intrusion, but until we can unite and get govt out of our lives, we'll have to run it at least some of the time.
My 1975 Pontiac Bonneville runs fine on it, no changes to the engine or fuel system at all from factory.
In The Ten Ring is offline   Reply With Quote
Old 03-14-2016, 11:31 AM   #12
67ChevyRedneck
I haven't had any problems with my mustang or C10 on it either. I have eliminated all rubber fuel lines except where my fuel filters are. I bought a new rebuilt carb for my 65 3 years ago. I recently had some problems with the car (turned out to be electrical) but pulled the top off the carb and inspected it. I've put about 15K on this car and it was completely clean.
I wonder if the people having problems are running a cheaper, non fuel rated hose that's breaking down and gumming up carbs?
Jesse James
Project "On a Dime"
Old 03-14-2016, 12:15 PM   #13
davepl
davepl's Avatar
No truck should have more than four inches of rubber hose total anyway! One piece where tank meets frame, one piece where frame meets pump.
Say it with me: No rubber after the pressure pump + no glass filters == No Fires
And the rubber hose you DO have must be fuel rated - gasoline eats rubber, but ethanol probably makes that worse.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-14-2016, 12:23 PM   #14
CCCC
CCCC's Avatar
Have been told that there is at least one very good/effective additive that will counter/prevent the damaging effects of ethanol. Can anyone here ID such additive(s) with certainty and cite a source/price? Thank for any useful info.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 03-14-2016, 12:50 PM   #15
ettsn
ettsn's Avatar
http://www.buyrealgas.com/Texas.html
ettsn is offline   Reply With Quote
Old 03-14-2016, 02:13 PM   #16
engineer_gregh
engineer_gregh's Avatar
I've ran E10 in my trucks (4) and Chevelle for years. I always add StaBil marine treatment at each filling and have had no problems. I will say that when I run 100% gas they seem to have more power and get somewhat better mileage. We can get both here in the Nashville area. E85 is only for newer vehicles labeled as flex fuel, my Denali with the 6.2 runs like a raped ape on it but fuel mileage drops by at least 20% compared to 93 octane.
In the Ten Ring is right; I caught flack last year when I said that I add StaBil marine treatment at each fill up when discussing this subject last year. It costs about an extra .05 cents per gallon to use it and it makes me feel better about running the ethanol blend. So please don't give me any crap about it.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 03-14-2016, 02:16 PM   #17
In The Ten Ring
I am not sure how much hose I have total, I did ask for fuel-rated hose but you know how smart auto supply store people can be. I have to redo my in-cab fuel line anyway, I'll go and have another look.
I am going to guess that I have about 7 inches of total hose, over the entire length. I might can decrease that a bit when I redo the in-cab pieces (yes, "pieces" ).
Old 03-14-2016, 02:26 PM   #18
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Who runs ethanol gas?
I drive my truck pretty much all the time. I have never had issues with E10 but it doesn't sit long a week are so at the most. I also have a 2004 6.0 FI.
E85 is for newer vehicles that can operate on it and you want catch me running it ever again if I don't have to no matter how high gas prices go.
Lawnmowers and weed eater are a different story.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-14-2016, 03:31 PM   #19
68Gold/white
The biggest worry with corn gas is what it can do to your carb. The float needle
almost always has a rubber tip on it, and the important part of the accelerator pump is rubber, also. Then there's the corrosive effect on the metal of the carb itself.
Injected vehicles have none of these worries.
I've heard of folks testing their E10 gas, finding out it's more than 10% ethanol, supposedly this problem is worse in cold climates, in the winter...?
68Gold/white is offline   Reply With Quote
Old 03-14-2016, 06:32 PM   #20
1968aj
Originally Posted by ettsn View Post
THANKS The nearest station on that site is 40 miles from me . I will go there and get some. the ethanol gas ruined the fuel system on my 2 lawn mowers; my weedeater; my chainsaw . it gets expensive rebuilding all of them. now I do not store them with gas in them . even by emptying the tanks just using ethanol it still screws them up.
Old 03-15-2016, 12:49 AM   #21
swamp rat
swamp rat's Avatar
I used to buy a product from Yamaha that would eat the alcohol out of 5 gallons of gas, don't know if they still make it, sold my WR250 a while back.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 03-15-2016, 02:37 AM   #22
87Skier
87Skier's Avatar
I have trouble now and then from E10. I've got a 72 Jimmy with a Quadrajet and an 87 Malibu skier with a 350 and quadrajet. The most important part is not letting the gas sit. My Jimmy never has fuel issues, but it got a new tank, rubber fuel lines, and a carb rebuild when I got it.
My boat is a problem child. It has an aluminum fuel tank and ethanol really hates aluminum. If I run regular gas the tank builds up an oxidation on the surface, which is fine. When I follow that up with ethanol it pulls all that off the tank which turns into a white powder and plugs up the fuel filters quickly. I always put a new filter in before leaving for the first trip and it doesn't always make it through that outing before I have to replace the filter.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 03-15-2016, 01:53 PM   #23
OregonNed
OregonNed's Avatar
No kidding about the dangers of rubber lines. Mine is minimal now too. When I bought mine in Idaho, and drove it all the way home - and then around for a few months, I didn't think to check mine. Then one hot day a bunch of us took a long cruise. The next morning I started it up, and kablooey! The line burst. Nothing was really hot yet, so I caught it. Gas spurting all over. Also changed out the glass filter on the manifold.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 04-16-2016, 05:49 AM   #24
dazza
dazza's Avatar
I think maybe it's possible that the ones having problems with rubber breakdown or carb build up might find that they're using GMO'd ethanol... ya never know what may happen in the future when messin' with corn genetics.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 04-16-2016, 07:19 AM   #25
I've used racing fuel for that purpose.
To answer the question asked in the title, everyone in my state. Marinas sell real gas and there is one station up by the MD/PA line that sells real gas. So, I guess there are a few who don't. Ethanol is yet another thing forced upon us for what a few feel is for our own good, when it is actually for the oil companies' way to get more money out of every drop.
