Old 03-11-2016, 11:57 AM   #401
60chevyjim
60chevyjim's Avatar
Re: A 15 year old's project. Rusty 62 stepside
here are pictures of how to check it .
remember the first thing to do is make shore the two u joints are lined up !
I lay the driveshaft on a flat surface to check this .
then do like in picture #1 first check to see that the space between the drive shaft and the square are even all the way down .
then check it from the other side also.
then check it like picture # 2 and #3 to see that the end cap looks spaced even when checked from both sides .
if it looks even all 4 ways then make 1 tack weld and check it all 4 ways again .
in picture #2 the square was not against the driveshaft like it should be
I couldn't hold the square and take the picture at the same time.
if it is good make a second tack weld on the other side . check it again to make shore it didn't move and if its all good then finish welding it.
try to make your weld even size all the way around.
if you get a fat spot in your weld then grind that spot to make it similar size to the rest of the weld.
60chevyjim is offline   Reply With Quote
Old 03-11-2016, 08:17 PM   #402
62stepside longbox
62stepside longbox's Avatar
Ok thanks for the pics.
Today I brought my yokes to school and pressed the ujoint out. It turns out there was plastic injected into the little holes in the yoke to hold the ujoint in so I heated it with a torch to melt it out then I pressed it out. I'm leaving to Maui today for a week but I'll be sure to post when I return.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 03-12-2016, 09:14 PM   #403
collin70k/20
collin70k/20's Avatar
Nice build! I'm 15 and working on a 1970 k/20 pickup for my first truck.
collin70k/20 is offline   Reply With Quote
Old 03-12-2016, 09:53 PM   #404
62stepside longbox
Thanks, I just checked out your thread and your truck looks Pretty nice. 4x4 must sure be fun in the snow.
Old 03-12-2016, 10:04 PM   #405
62stepside longbox
I thought I'd show you guys some pictures of my flight to Maui
Old 03-13-2016, 05:00 AM   #406
Grizz1963
Grizz1963's Avatar
Originally Posted by 62stepside longbox View Post
i thought i'd show you guys some pictures of my flight to maui
TEASE...........
Loads more pics.
And allsorts, remember we like loads of stuff on here.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 03-13-2016, 07:07 PM   #407
62stepside longbox
Saw this today at a beach in Maui. 1966 custom camper (badges removed when painted) with a 283 3 on the tree original interior and original bed wood, owned by a surfer.
Old 03-13-2016, 07:22 PM   #408
TJ's Chevy
TJ's Chevy's Avatar
That's a nice looking truck!
Old 03-13-2016, 08:44 PM   #409
62stepside longbox
Yeah I didn't expect to see one here. As soon as I saw it I went running over to talk to the guy about it.lol
Old 03-15-2016, 01:41 PM   #410
62stepside longbox
Saw this one in Maui last night. Not a 60 to 66 but still cool. Either a 55 or 56. Surfboards on the bed read " gas monkey tattoos". It seems like it's been on the island for a while, You can't tell by the pictures but it has a ton of rust. I think they just use it as advertising because it looks like it hasn't been moved in a while.
Old 03-15-2016, 01:42 PM   #411
62stepside longbox
02
Old 03-15-2016, 01:44 PM   #412
62stepside longbox
03
Old 03-19-2016, 02:51 PM   #413
62stepside longbox
Another cool car in Maui. This is probably the nicest one on the island. 65 Nova with a 230, original colour, in showroom condition.
Old 03-19-2016, 02:52 PM   #414
62stepside longbox
02
Old 03-20-2016, 07:17 PM   #415
rusty76
rusty76's Avatar
Cool rides. Wished I knew you were going you could have taken us. Lol. Have fun.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 03-20-2016, 10:03 PM   #416
62stepside longbox
Ha sorry I don't think my suitcase is large enough for people.
Old 03-20-2016, 10:10 PM   #417
62stepside longbox
Just got back this morning and got busy. Finished off the sectioning of the front fender but then found some more rust in the lip.
Here it is cut out
Old 03-20-2016, 10:11 PM   #418
62stepside longbox
Here is the metal completely finished on the fender
Old 03-20-2016, 10:13 PM   #419
62stepside longbox
Then I decided to start on the tailgate cables
I used I hole saw on the bedside in the mid stake area
Old 03-20-2016, 10:14 PM   #420
62stepside longbox
Then I found a washer the same size as the hole and welded a nut to the backside
Old 03-20-2016, 10:16 PM   #421
62stepside longbox
Then I welded it in flush and blended it smooth
Old 03-20-2016, 10:17 PM   #422
62stepside longbox
Here's the cable bolted on
Old 03-20-2016, 10:37 PM   #423
TJ's Chevy
TJ's Chevy's Avatar
Looks good! Hope the trip was a blast.
Old 03-21-2016, 12:02 AM   #424
bumwine
bumwine's Avatar
Looking good
bumwine is offline   Reply With Quote
Old 03-21-2016, 10:54 PM   #425
62stepside longbox
Thanks tj, yeah it was a lot of fun
Originally Posted by bumwine View Post
Looking good
Today I cut the driveshaft down to exactly the corect length by installing it and slipping the yoke in the transmission and pulling it out about 3/4'' then making a mark, for the cut I found a piece of tubing slightly larger with a straight edge and used it as a fence to cut against. Checked with the square and levels many times and the cut is 100% straight
