Old 03-11-2016, 08:05 AM   #1
AASmedic
AASmedic's Avatar
NP205 Question
Good day all,
I made the mistake pulling the cover off of the rear of the front output shaft and all of the needle bearings fell out. I forgot that it had that type of bearing there. Does anyone know how many needle bearings there are suppose to be there?
AASmedic is offline   Reply With Quote
Old 03-11-2016, 08:14 AM   #2
AASmedic
AASmedic's Avatar
Re: NP205 Question
In case anyone is wondering, this is what I am talking about.
Old 03-11-2016, 08:43 AM   #3
midniteblues
midniteblues's Avatar
Re: NP205 Question
I can't answer your question. But if ya use some grease or Vasaline to hold them in you could line them all back up.
If ya have a gap about the size of one or two then you know you answer.
Just like a u joint.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 03-11-2016, 08:47 AM   #4
AASmedic
AASmedic's Avatar
Re: NP205 Question
Ya, I did the grease trick. I have enough space for 1 more and that's what I was afraid of. I have lost one of the little suckers.
Old 03-11-2016, 08:49 AM   #5
AASmedic
AASmedic's Avatar
Re: NP205 Question
now gotta find the correct replacement
Old 03-11-2016, 08:53 AM   #6
midniteblues
Re: NP205 Question
A good magnet might help ya find one if you know the general location.
I don't know how bad I would fret about one but I've never had one apart.
I did the same thing with a power steering gear.
Old 03-11-2016, 01:47 PM   #7
BlueBullet
BlueBullet's Avatar
Re: NP205 Question
There is a really good right up in the 4x4 section at the top.
1972 K10 SWB wife's driver
1967 Pontiac GTO
Big Bird - 1972 Longhorn K30
http://67-72chevytrucks.com/vboard/s...d.php?t=753294
BlueBullet is offline   Reply With Quote
Old 03-11-2016, 03:21 PM   #8
SS Tim
SS Tim's Avatar
Re: NP205 Question
Not often I can't find something but this isn't a quick one for me. Checked the factory service manual, chevy parts manual, np205 parts catalog and even the LoMax 205 conversion instructions from JB Conversions. Most only suggest the bearings none give me a count like the primary needles inside the case, 128 (32x4) and 15. The best picture is from JB Conversions and it looks full. Might just try giving them a call 337-625-2379 and see if they can tell you.
SS Tim is offline   Reply With Quote
Old 03-11-2016, 03:24 PM   #9
AASmedic
AASmedic's Avatar
Re: NP205 Question
Thanks for the suggestions
Old 03-11-2016, 04:57 PM   #10
AASmedic
AASmedic's Avatar
Re: NP205 Question
So, no one has any specific information. I count 40 and there is just enough space for one more. Would these have been manufactuted with an odd number??
Old 03-11-2016, 05:40 PM   #11
Billhilly
Billhilly's Avatar
Re: NP205 Question
Bearing is a Torrington M28161, can't help with roller count sorry!
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 03-11-2016, 06:00 PM   #12
SS Tim
SS Tim's Avatar
Re: NP205 Question
Quad 4x4 has them.
Looks like the individual needles are not sold seperately too.
http://www.quad4x4.com/tk50357.html
http://www.quad4x4.com/images/205tech2.jpg
Old 03-11-2016, 06:22 PM   #13
AASmedic
AASmedic's Avatar
Re: NP205 Question
You are correct on the bearing number. Thank you sir.
Old 03-11-2016, 06:30 PM   #14
SS Tim
SS Tim's Avatar
Re: NP205 Question
Seeing 40 needles most of time I try and count them... if the number shown are the full and correct count.
Old 03-11-2016, 06:43 PM   #15
AASmedic
AASmedic's Avatar
Re: NP205 Question
Is 40 the correct number though? I was unable to get an accurate count because they all fell out when I pulled the cover off. I have searched the floor of my shop and the inner case but I cannot find any more.
Old 03-11-2016, 10:14 PM   #16
dazza
dazza's Avatar
Re: NP205 Question
I will be back to my truck tonight or first thing in the morning. I have all the old bearings from when I rebuilt mine except I may have used one or two for some art project. Pretty certain that particular one is there and will have a look for you. If nothing else, I could even drop a few in an envelope to you.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 03-11-2016, 10:22 PM   #17
AASmedic
AASmedic's Avatar
Re: NP205 Question
Thanks dazza. Every other set of needle bearings in the NP205 has a specific number in the set......except that one. I appreciate you sending me the info.
Old 03-12-2016, 01:50 AM   #18
dazza
dazza's Avatar
Re: NP205 Question
I've also started going through my photos and posting for reference if anybody needs. So far, np205, sm465, and winch. A lot of duplicates but different angles just in case, I've often found what I'm looking for in the background of a picture that I didn't even know was there!
------> np205
Old 03-12-2016, 12:20 PM   #19
ajviper
ajviper's Avatar
Re: NP205 Question
Give Off Road Design a call. They rebuild NP205s and should be able to give you a quick answer.http://www.offroaddesign.com/index.htm
Chevy Runs Deep.
1956 210 LS1 TH350 3.31 Posi 12 Bolt
1969 Z/28 5.3 T56 3.73 Posi 12 Bolt
1973 Nova SS 355 TH350 2.73 Posi 12 Bolt
2000 K2500 Suburban LS 6.0 4L80 3.73 G80
2005 K2500HD CCSB LS 6.0 4L80 4.10 G80
2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic
ajviper is offline   Reply With Quote
Old 03-13-2016, 07:44 PM   #20
dozerbill72
dozerbill72's Avatar
Re: NP205 Question
I have two covers with the bearing still in them and both had 41 rollers. I counted them both twice to make sure my eyes where working.
dozerbill72 is offline   Reply With Quote
Old 03-13-2016, 07:58 PM   #21
AASmedic
AASmedic's Avatar
Re: NP205 Question
Thanks for the info. I found the last one this morning. It had fallen into a crack on my work vench
Old 03-13-2016, 09:38 PM   #22
dazza
dazza's Avatar
Re: NP205 Question
that's why I don't like the vench, too many things get lost in the v.
Old 03-13-2016, 09:43 PM   #23
dazza
dazza's Avatar
Re: NP205 Question
Apparently, the one I had is a pile of needles, qty 39. The only other one I have is a 27 count.
So the mistake of pulling the cover, were you just curious as to what makes that thing tick or you planning to rebuild it?
Old 03-13-2016, 10:19 PM   #24
AASmedic
AASmedic's Avatar
Re: NP205 Question
No, I'm rebuilding it. I just wanted to be sure I didn't loose any. My mistake was not pulling it with caution.
