Old 03-14-2016, 12:13 PM   #26
daddyjeep
daddyjeep's Avatar
Re: Sqaure body swap onto 88+ frame?
I am not crazy about the body mount adapters on the build above. All the weight of the cab resting on some 1/4" plate mounted on top of bushings. If I were to attempt that swap I would build a much stronger mount than that. Just my $0.02.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
