Got big-block?
![]() Join Date: Jul 2000
pics of ECE trailing arm braces welded on....
Here's a couple of pics of Project Daisycutter's newly braced/stiffened trailing arms using the kit from Early Classics.
Fit perfect. Now to prep and paint with POR-15. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
Got big-block?
closeup
Failure is NOT an option!
What do those help by stiffening them?
House payment or truck parts?????.........why does life have to be so complicated? 1969 Chevy Shortbed Fleetside 1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto) 1990 Ni$$an hardbody( daily beater that has been really beaten!) 1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me) |
![]() Join Date: Aug 2001
I would assume they're more for twisting support than bending or something. I may need to check into these also. Do they run the entire length of the arm?
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
I've seen that type of reinforcement on trailing arms before in magazines and here on the board. Frankly, I don't see that helping much of anything. I've had a little formal education in engineering and quite of lot of on the job engineering. When I re-did my trailing arms I cut pieces of 3/16" plate and welded them inside the arm to increase the strength of the "I" part. They (the trailing arms) are in the configuration of an "I" beam and it is the vertical part that gives the top load strength. There isn't really much twisting forces on these arms. The physics forces are compression front to rear from acceleration and down load from the springs.
Black 72 Chevy
Here early classics has some info about this kit.
http://www.earlyclassic.com/techarti...boct03pg1.html |
I am not doubting ECE's kit for what their application is. I have bought quite a few of my suspension components from them and know them to be very reliable. I still want to stress if you think down load could lead to problems and I know these arms can actually break (I have an acquaintance to whom this happened) they need re-inforcement on the inner part. ECE is mainly offering this part to avoid separation of the two parts of the arm because of rust and deterioration.
