Old 03-14-2016, 05:17 AM   #1
geunther
geunther's Avatar
OEM 12 bolt diff cover
My diff cover had been overtightened..a lot. To the point that you can see the bolt shoulder circle imprinted on the inside of the cover. Some of the shoulders had cut into the cover. I can spend some time hammering it back into shape but with the cutting into the cover, I think its better to replace.
Anyone know of a good source? Ive looked at all the typical sites already. I can't find any with the factory raised ribbing between bolt holes, and the curled back flange. No decent junk yards in the area.
geunther is offline   Reply With Quote
Old 03-14-2016, 06:51 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: OEM 12 bolt diff cover
Post a Want to buy ad in the classified or drive line forums .i'm sure someone must have an extra or two .
Old 03-14-2016, 02:46 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: OEM 12 bolt diff cover
I just bought this one.
Chevy/GM Truck 12 Bolt Chrome Steel Rear Differential Cover 8.75" Gasket & BoltsChevy/GM Truck 12 Bolt Chrome Steel Rear Differential Cover 8.75" Gasket & Bolts
http://www.ebay.com/itm/331099600312...ht_2465wt_1124
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-14-2016, 03:19 PM   #4
68Gold/white
There are aftermarket covers available. If you decide to go that direction, beware, the 12 bolt truck covers are different from the car units.
68Gold/white is offline   Reply With Quote
Old 03-14-2016, 04:42 PM   #5
geunther
geunther's Avatar
Posted a WTB in classifieds. Trying to keep it original. Aware of the difference between trucks and cars but would rather be told 100 times than not know. That would have been frustrating to have bought one of those by mistake.
