Old 11-30-2015, 03:37 PM   #101
69CST-V
69CST-V's Avatar
Re: "Albert" -- 1949 AD, S10 Chassis
Nice work....Sub'd
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 12-12-2015, 02:38 PM   #102
IWanna49
IWanna49's Avatar
Very nice, clean work!!
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 12-12-2015, 02:51 PM   #103
joedoh
joedoh's Avatar
Originally Posted by HUSSEY View Post
Not sure why I needed a separate bracket that bolted in-between the frame and bumper but that’s what I came up with.
maybe someday you want to run with no bumper, ADs look good like that. I had a 65 chevy and the front bumper mounts were part of the end of the framerail, so without a bumper it looked cool but had those bumper mounts sticking out. so it was run a bumper or cut the frame off.
anyway, your truck looks fantastic!
joedoh is online now   Reply With Quote
Old 12-27-2015, 11:13 PM   #104
WorkinWrenchs
This is a lot of great information. I may be using some of your ideas here and there especially on the radiator mount. Keep the pics and info coming along. The truck at this rate will be done in no time.
'53 GMC 5-Window Build
WorkinWrenchs is offline   Reply With Quote
Old 12-30-2015, 02:51 PM   #105
HUSSEY
HUSSEY's Avatar
Sounds like as good of an excuse as any. I have seen a couple without front bumpers and they have a cool look of their own if they're sitting nice and low like your truck above.
My 49 AD Build / S10 Chassis -- Thread -- Pictures -- S10 Conversion Mounts
HUSSEY is offline   Reply With Quote
Old 12-30-2015, 02:52 PM   #106
HUSSEY
HUSSEY's Avatar
Thanks man, this site has been a wealth of information for me!
Old 12-30-2015, 02:53 PM   #107
HUSSEY
HUSSEY's Avatar
Just for the hell of it I set the truck on all four tires last night wanting to see where it sat. I had a couple folks asking how high I thought the running boards would be off the ground. The front bumper is about a 1/2 in. taller than a beer can. The back of the front fenders are sitting right at 6 in. off the ground. There may be some front coil trimming in the future but I think I’ll be leaving the front at this ride height until I get it on the road and see just how much lower I can go. I would like to get the back end dropped some more to get the truck sitting level, but I won’t mess with that until all the metal is in place.
Old 12-30-2015, 04:41 PM   #108
DeanTX
DeanTX's Avatar
Thanks for the update. I think it looks perfect where it sits now.
DeanTX is offline   Reply With Quote
Old 12-30-2015, 04:41 PM   #109
iowaboynca
iowaboynca's Avatar
I think the stance looks good as is but that's me but i see what you mean about the getting the bed on. keep it up!
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 12-30-2015, 04:53 PM   #110
DeanTX
DeanTX's Avatar
Hussey, did you ever mention how many owners "Albert" has had? I'm curious because the fact the name stayed on the truck might mean you are only the 2nd owner.
For my 1951, I am the third owner. The second owner had it since 1960 or so.
Old 12-30-2015, 06:59 PM   #111
HUSSEY
HUSSEY's Avatar
I'm going to guess that I'm the third owner to make use of the truck, for me the sheet metal that is.
I know Albert Reeter wasn't the first owner because you can see a ghost image of painted door letters behind his. After Albert a guy bought it at the Reeter farm auction. He kept it for a while with hopes to get it going one day. After some time he then sold it to his son. Same story there. That's when I became the current owner.
If you look on the door it's from Chillicothe, MO which is also where I bought it from. They have a car show there every year and I hope to take it back when I'm done with it, I'm sure it'll get some attention just from the door letters.
Old 12-30-2015, 09:57 PM   #112
DeanTX
DeanTX's Avatar
Sounds like it stayed its whole life in Chillicothe until you found it.
Old 12-31-2015, 01:16 AM   #113
99 to Life
99 to Life's Avatar
always fun putting metal on. amazing how fast you can build a truck (moch up!) then amazing how long it takes to really build the truck.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 12-31-2015, 08:23 AM   #114
Coach529
Coach529's Avatar
I love the stance.......looks great!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 02-22-2016, 02:48 PM   #115
HUSSEY
HUSSEY's Avatar
Running boards are mounted up. I saw a few different methods out there, I got this idea from chopit on 67-72chevytrucks. It worked out well for me. My boards had been patched by the previous owner which I think warped them. You can see I had to clamp the running boards down to my welding bench since they were warped so bad. Building this “frame” helped hold them straight making it easier to get them mocked up to the cab. I used 1x1.5 in. 11 GA for the frame and 1.5x3 in. 11 GA for the mount that bolts to the frame. My forward mount is mounted just behind the splice on the frame which is nice flat spot. The rearward mount is forward of the rear of the cab.
Old 02-22-2016, 07:44 PM   #116
99 to Life
99 to Life's Avatar
very nice, def one of the better designs I'v seen. its a PIA on the last mount because of the leaf perch. you handled that well. I also like how you bolt them on. thats how I do them.
Old 02-22-2016, 09:01 PM   #117
HUSSEY
HUSSEY's Avatar
Thanks! Yep, on mine both the front and rear mount would have interfered with the rear hitting the leaf spring shackle and the front hitting the body mount.
I chose to bolt them on so I could also tweak them up and down without shimming the running board. Right now I just have the running board frame tacked to the frame mounts. I lined the boards up with them touching the rubber flap thing, not sure what you call it, behind them under the cab. I wasn't sure of exactly where they would need to be until the bed was in position.
Old 02-22-2016, 10:53 PM   #118
joedoh
joedoh's Avatar
nice work like always! very simple and clean
Old 03-15-2016, 01:08 PM   #119
HUSSEY
HUSSEY's Avatar
After some adjusting and tweaking of my running boards I started getting the bed fitted up. So far I have the right side mocked. I had picked up some wheels a couple of weeks ago on CL and couldn’t resist bolting them on to see how they looked.
The wheels are American Racing Torq Thrust 2 18x8. The previous owner had them on an 88 Monte Carlo SS. The tires are 245/40-18 Brigestone Potenza.
The tires are a little thinner profile that what I would like but the wheels and tires were close to new and I paid $750 for the set with lug nuts so…I can live with it.
I’m looking forward to getting the bed finished, sitting it on the ground, and rolling it outside to see how it looks.
Old 03-15-2016, 01:46 PM   #120
84blaze
Looks great dude.
Can you should some photos of how your mounting the bedsides to the bed floor?
84blaze is offline   Reply With Quote
Old 03-15-2016, 03:16 PM   #121
HUSSEY
HUSSEY's Avatar
Originally Posted by 84blaze View Post
Looks great dude.
Will do. Hope to have the bed supports finished up in a week or two.
Old 03-15-2016, 04:34 PM   #122
1952ssr
1952ssr's Avatar
Wheels and tires look good, my 18x8's run 225/40/18's. Great fab work, I like your running board mount idea. The way your front bumper mounts is exactly how I was planning on doing my new build, so much easier than the first one. I will be keeping up with your build.
1952ssr is offline   Reply With Quote
Old 03-16-2016, 10:14 AM   #123
lsjrl07
lsjrl07's Avatar
So many good ideas in this build! Good Work Hussey.
lsjrl07 is offline   Reply With Quote
Old 03-16-2016, 12:13 PM   #124
HUSSEY
HUSSEY's Avatar
Dude, I like the spinners on your wheels. What are yours? I'd like to get some for mine but from AR they are CRAZY expensive, something like $100 a piece.
I've seen the chromed plastic set for 99 and also a chrome aluminum set for 199 on eBay. I've been told to steer away from overseas chrome aluminum, it's just going to fail sooner or latter. The AR spinners are polished aluminum.
My center caps are engraved American Racing with an SS in the middle so they my be worth some money to someone.
Thanks bro!
Old 03-21-2016, 12:26 PM   #125
BigFrz
[QUOTE=HUSSEY;7524629]Dude, I like the spinners on your wheels. What are yours? I'd like to get some for mine but from AR they are CRAZY expensive, something like $100 a piece.
Nice build man. I just couldn't find any pics of the font or the rear bed mounts. I am in the process of lining thy up on my frame and putting mounts on. 1
BigFrz is offline   Reply With Quote
