03-16-2016, 10:51 PM | #1 |
any one repair kinks and dings on frame. to straight it out?.
Well i got the hole frame stripped down so I can blast and trying to take out the trans x member.. and I have a kink that the p.o. have used a jack on c channel lip where it drops off rear of Trans x member ..i belive he Jack it obviously in the wrong place and just bent up the lip on one the c channel one side where it drops. off.I Would like to straight thing out the best way possible with out any damage.. was think cut the bottom lip area out in a square and welding in a new piece or doing three relive cut in the frame bent area. And bending back flush.. also a have o/a tanks but don't like to use that 4 any frame work..any suggestions with this topic?
03-17-2016, 12:13 AM | #2 |
Re: any one repair kinks and dings on frame. to straight it out?.
Should be able to straighten it out. A pic or two would be helpful.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
03-17-2016, 07:00 AM | #3 |
A little heat and the largest Cresent wrench you have should bring it back to where your happy with it without cutting anything .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
03-17-2016, 09:04 AM | #4 |
motor exploder
x2 on the crescent wrench, if it's big enough you shouldn't even need any heat. It's what I used to fix similar issues on my frame.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
03-17-2016, 11:01 AM | #5 |
C10 Collector
^ These dudes got it right. I have a 4' long crescent wrench just for straightening frames. Just the weight of it will do the trick sometimes with a little heat in the right spot.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
03-17-2016, 11:35 AM | #6 |
Great advice on straightening. Be careful on the heat. It can change the metal a little and cause a weak spot. You see this come up a lot when people want to cut, weld, or extend a frame. Done properly it is not a problem. Excessive heating is definatly a problem. Use what is needed and no more and you should be happy with the outcome.
03-17-2016, 11:43 AM | #7 |
I get a little crazy about how the frame looks . To me it's just as important as a fender /door . What drives me nuts is watching someone bolt thousands of dollars of brand new suspension to a rusty/greasy/bent frame ??? End of rant
03-17-2016, 11:50 AM | #8 |
Most frames are pulled cold. I don't know, but I wonder how much heating up the metal changes the annealing or hardness. It's mostly a curiosity unless its around a mount point, but at a mount might heat change the metal properties?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
03-17-2016, 12:12 PM | #9 |
C10 Collector
Im not sure if C10 frames were heat treated from the factory. Probably not. They were most likely cold worked with tightens the grains up making them a bit harder and stronger than hot worked steel. Problem with this is if you put excessive heat into the rail the molecules will spread and you will get a hicky/lump where you heated it. Dont let the frame become more than a soft orange between the wheels, thats where you need the most strength. At the ends around bumper mounts and such heat as necessary to get it straight. You could also quench if you need to shrink it some but be careful as you can make it too hard and make it prone to cracking.
With the way these frames were made with all the rivets they are pretty fluid and I wouldn't be too concerned with put a little heat on it but dont get crazy.
03-17-2016, 12:42 PM | #10 |
motor exploder
I'm the same way
03-17-2016, 02:21 PM | #11 |
That's one rigid looking frame! Nice.
03-17-2016, 03:16 PM | #12 |
That is purty. Don't look at mine though. She is a daily driver and part time work truck this rebuild. Maybe in a few years the undercarriage will get some love but until then you can still see where the fire department welded a full cage to the frame. I cut it off as close as the sawzall would get and called it good. I still have people tell me how good it looks and have someone try and buy it at least once a month. I guess being a 4x4 people expect it to not look brand new.
03-17-2016, 06:15 PM | #13 |
Thanks it worked! Nice little trick to know..
03-17-2016, 07:36 PM | #14 |
Thank you , Thank you very much, We'll all be here all week !
03-17-2016, 09:15 PM | #15 |
