Old 03-17-2016, 11:12 PM   #1
crazyjim
crazyjim's Avatar
Question about flip kit
I see that the part that the rear end sets in has a hole in it and it's off center does that hole go back of the rear end or the front?
crazyjim is offline   Reply With Quote
Old 03-18-2016, 03:43 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Question about flip kit
Hole to the front, the axle has to go back for the driveshaft
Old 03-18-2016, 08:09 AM   #3
riz
I just installed my McGaughey flit kit and the hole goes to the front.
RIZ
riz is offline   Reply With Quote
Old 03-18-2016, 07:40 PM   #4
crazyjim
crazyjim's Avatar
Thanks guys, I was also I was wondering when you buy 2.5 drop spindles can I cut my stock springs on the front and use them ?
Old 03-18-2016, 08:47 PM   #5
crazyjim
crazyjim's Avatar
Cant wait to see it lowered.
Old 03-18-2016, 09:29 PM   #6
SkinnyG
SkinnyG's Avatar
You can totally cut the coils when you're doing spindles. Most guys lop a full coil off.
I prefer the tops of the tires even with the top of the fender edge, so I cut the coils until it sits at that height.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 03-18-2016, 09:30 PM   #7
SkinnyG
SkinnyG's Avatar
What's the backspacing on those back wheels? If they are less than 5", you may have some clearance issues with a flip.
Old 03-18-2016, 09:58 PM   #8
crazyjim
crazyjim's Avatar
I'm not sure.I'm planning on new wheels and tires.
Old 03-18-2016, 10:01 PM   #9
crazyjim
crazyjim's Avatar
Is the backspacing how deep the wheels is ?
Old 03-18-2016, 10:04 PM   #10
crazyjim
crazyjim's Avatar
That's how I like them to set,Do you have any pics of your truck ?
Old 03-18-2016, 11:34 PM   #11
SkinnyG
SkinnyG's Avatar
Backspacing is the distance the mounting flange to the backside of the rim. 5" will tuck.
Pictures (front: Belltech 3" spindles, 1-ton coils, 1-3/4 coils removed. Rear: flip kit, heavy leafs.):
Old 03-19-2016, 01:07 AM   #12
crazyjim
crazyjim's Avatar
Sweet looking truck.
Old 03-19-2016, 11:51 AM   #13
Shady Rascal
Shady Rascal's Avatar
3" spindles with one coil cut off of stock springs in front. Flip in the rear. You have to be careful with backpacing when dropping low like this. Not that it was much of an issue in this case because my wheels are pretty skinny.
Shady Rascal is offline   Reply With Quote
Old 03-19-2016, 07:02 PM   #14
95chev-w/t-guy
95chev-w/t-guy's Avatar
I have a flip kit in the back, currently cut coils in the front, about 3 (or more) coils cut out of the stock 1/2 ton springs (they were cut before I bought the truck, and the literally fall out with the front end of the truck on jacks). I got drop spindles and what I was told were lowering springs when I bought them, but I now believe they are stock springs. When I put the drop spindles in, I think they're 3", and the flip kit in the back I think is a 4-5" setup, I'm hoping the truck will more or less sit level given that it likely had a slight rake when it was stock. If it ends up dragging it's rear a little bit that's ok too.
1984 c10 - my forever truck
1991 GMC R2500 6.2 Diesel
1995 GMC K2500 LQ4 swap coming soon
2002 2500hd cclb LQ4/NV4500 2wd - parted out
1998 c1500 - sold for parts
1995 c1500 - sold to my brother, then sold again but still going
95chev-w/t-guy is offline   Reply With Quote
Old 03-20-2016, 11:48 AM   #15
crazyjim
crazyjim's Avatar
Got flip kit in look's good.
Old 03-20-2016, 12:13 PM   #16
lolife99
67-72 parts collector,…
lolife99's Avatar
Make sure you trim the bottom of those u-bolts off!
Keith
Convert to disc brakes.
Old 03-20-2016, 12:30 PM   #17
SkinnyG
SkinnyG's Avatar
But leave at least half an inch, in case you need to shim the axle to correct any pinion angle issues.
Old 03-20-2016, 12:59 PM   #18
crazyjim
crazyjim's Avatar
10-4 big buddy.
Old 03-21-2016, 08:14 AM   #19
riz
Buy drop coils. Don't mess with cutting them.
RIZ
Old 03-21-2016, 08:19 AM   #20
Shady Rascal
RIZ
Why spend the money ?
Countless guys, myself included, have been cutting one coil off of stock springs for decades and been completely satisfied with the results it gives.
Old 03-21-2016, 11:57 AM   #21
KQQL IT
At the body shop.
KQQL IT's Avatar
Every square I've had didn't even get spindles, clip 2 with a chop saw.
Didn't have money for spindles then, do now. But like the results.
Clip 2 and flipped out back.
Old 03-23-2016, 08:27 PM   #22
beltfedbill
Why is the hole off-set? If the axle is centered below the leaf pack on the tie bolt. What would change if it were centered on the top side of the leaf pack ? The reason I ask is that I bought axle perches , which have a center tie bolt hole, u-bolts and lower plates at work. All for under $50. I planned on flipping the axle, use the new perch and weld axle to perch, after setting the right pinon angle of course?
beltfedbill is offline   Reply With Quote
Old 03-23-2016, 09:33 PM   #23
KQQL IT
At the body shop.
KQQL IT's Avatar
Driveshaft needs shortened otherwise
Old 04-07-2016, 04:24 PM   #24
LDO
LDO's Avatar
Jim, which kit is that? I can't seem to find one that comes with the bump stops.
LDO is offline   Reply With Quote
Old 04-07-2016, 06:40 PM   #25
bbbc10
Diggin The SquareLife
It has the name brand in the pic....lol try ebay or the website
bbbc10 is offline   Reply With Quote
