03-18-2016, 04:51 PM | #1 |
How do you grease steering shaft?
How are you supposed to grease the boot for the intermediate shaft? Mine feels empty. Short of poking a hole in it I don't see a way unless you take it apart. Thanks in advance.
http://67-72chevytrucks.com/vboard/s...25#post7532025 71 Cheyenne K10. 283/Th350/NP205. 3.07s non posi. 31x10.5 Bighorns.L31 350 Vortec swap in progress. 79 Suburban K20. 350/350. 6" lift. 35x12.5 Toyos. 93 Burb K1500. 350/4l60e Parting out. 2001 Tahoe LT, 5.3, autoride, 265/75s, leather, loaded, family hauler, 243k miles! |
03-18-2016, 06:34 PM | #2 |
Keepin an eye out
Re: How do you grease steering shaft?
This should help...Just did mine, not to terrible.
http://67-72chevytrucks.com/vboard/s...d.php?t=420406
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
03-18-2016, 07:39 PM | #3 |
Have a look at the Cherokee intermediate shaft mod. They cost $13 at the pick a part around here, and there are always a few there. It takes a couple minutes to pull.
https://www.google.com/search?q=Cher...ng+shaft+chevy |
03-18-2016, 08:38 PM | #4 |
Pulling it apart doesn't take very long, and if you have any play in the coupler, you can remove the square wear parts, rotate them 90*, and reduce slop...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
03-19-2016, 11:19 AM | #5 |
First off thanks for the advice you guys. Franken-I'm not into switching to the jeep shaft just yet but a great idea and looks good too. Borax- Nice shaft you have there(no jokes here either ). I'm just going to pull it and clean it up real nice for now and when I do a frame off and everythings new ill consider the jeep option. Joey- thank you. A good way to make the parts last a little longer and that gives way for money elsewhere. Ill post before and after pictures when I get done.
03-19-2016, 11:36 AM | #6 |
If you need parts they are kinda hard to find but this is what I used...
http://67-72chevytrucks.com/vboard/s...d.php?t=683346 Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
