XM Radio Antenna Mounting Location?
So I have this Sirius XM radio antenna for my kenwood head unit that is installed in my '57. I was wondering if anyone else has a similar antenna and where you mounted it? I want to put it in a spot that is not too noticable but still will get good reception. The base is magnetic so I can obviously just take it off and throw it in the truck when i get to shows, but it would be nice to find a good spot that i can just leave it alone. Pictures would be much appreciated!!
Re: XM Radio Antenna Mounting Location?
Glue it to the inside of the back window?
Old Heap Driver
Mine is mounted (50 Chevy) in the left rear stake pocket. Bent a 90 in some sheet metal and screwed it to the inside of the pocket, ran the antenna wire through the pocket, mounted the antenna to the sheet metal, done. the reception is awesome.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
if it works behind glass, try the back window or the corner of the dash
if not i like the stake pocket idea
cool, an ogre smiley Ogre's 58 Truk buildhow to put your truck year and build thread into your signature shop air compressor timer |
I tried it in the corner of the dash but it didnt seem to get good enough signal. Im assuming the glass and overhang from the roof mess with the signal. So i dont think the back window would work because the antenna would be facing inside the truck (top is rounded and bottom is flat with magnet). I do like the bed stake idea but the problem is, i dont have any stake pockets lol.
I have run them in various vehicles on the center front dash behind the windsheild has worked fine in my 98 GMC, 87 Buick Regal, and 95 Ford Explorer......but on my 87 GMC the front corner dash hasnt worked good at all a lot of dropping out when pointing north.....Im gonna the center front dash on it since it was installed by Best Buy in the front corner....but the stake bed ideal sounds like good back up......do you have any pics of it installed in the stake bed hole?
http://i204.photobucket.com/albums/b...baae5d9a7e.jpg |
Old Heap Driver
I'll grab a picture this weekend of the cab pocket mount. Just to add, the top of the dash on my 80 C-10 never worked properly for an XM antenna. I have a tiny area exposed on the bed rail (stepside with a tonneau cover) near the back window, works much better.
They need to make them for vintage vehicles. The mast could be a dummy, with the base being the 'tenny. I don't know anything about it. Justa thought.
not a fan of xm, i play mp3s on an 8gb thumb drive and rarely hear the same song
i'd like to see a xm antenea delete for my 09 gmc
#10 | |
Old Heap Driver
Finally grabbed a picture as requested.............
Can the XM antenna wire be lengthened with a splice of ordinary stranded wire?
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
Old Heap Driver
The cable is plenty long. I don't think you can splice it anyway.
#14 | |
#15 | |
Old Heap Driver
Quick check on eBay, the cables are 23 feet and an extension cable of 20 feet is also available.
#16 |
Thanks for the suggestion!
#17 | |
![]() Join Date: Oct 2012
#18 | |
Old Heap Driver
http://www.ebay.com/itm/Sirius-Satel...0AAOSwu1VW2h-h
| Bookmarks |
| Tags |
| antenna, radio, sirius, xm radio |
