Old 03-21-2016, 01:08 PM   #10
CSHADES
CSHADES's Avatar
Re: Steering Wheel Swap
I don't have a picture of that. It was something I came up with because some of the aftermarket steering wheel adapters were rubbing on the columns. What I ended up doing was using my brake lathe with the small arbor that I have. I chuck up the wheel and use the drum turning tool to slowly turn the bottom mount flange down until I get enough clearance on the column. I have an accu-turn brake lathe I don't know how other lathes will work.
CSHADES is offline   Reply With Quote
steering wheel, swap
