Old 12-07-2009, 11:24 PM   #1
68 short step
LS series PCM mounting
ive gotten a few questions on where/ how i mount my PCM for the LS (4.8 5.3 5.7 6.0) engines.... i use the factory truck PCM mount, cut off the backside (so im left with a box)....then i make some angles, one side 'rests' inside the factory notch on the firewall (the one im pointing to), this also locates it...then you can either weld the tabs on, or drill holes in them and bolt them to the firewall.....the PCM simply slides/snap in the holder, makeing for easy removal if neccessery...
68 short step is offline   Reply With Quote
Old 12-08-2009, 01:56 AM   #2
Ackattack
Ackattack's Avatar
Re: LS series PCM mounting
looks nice
I mounted mine on a sheet metal mounting plate on the inside of the firewall.
Ackattack is offline   Reply With Quote
Old 12-08-2009, 02:29 AM   #3
POPO1984
POPO1984's Avatar
I dont know about mounting it there. Its gonna be pretty hard to get to once engine and trans are in
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 12-08-2009, 08:17 PM   #4
68 short step
i have it mounted there in my black truck, ive had to change the computer in it before...took all of 5 mins, and 4 of which were getting the screws loose to get the PCM connectors off.
Old 12-09-2009, 09:18 PM   #5
mcbassin
Still Learning
mcbassin's Avatar
I guess you have to have your motor mounts set just right to have sufficient clearance to access it right? Just saying, when you mount your motor in the frame, is it possible to have it mounted too far back?
Mike
Old 02-13-2016, 09:39 PM   #6
elf w/capital T
shnnaaazzzyyy
elf w/capital T is offline   Reply With Quote
Old 02-13-2016, 11:31 PM   #7
Robznob11
Robznob11's Avatar
Mine would not fit there for sure. Seems it would be a hassle to take out. I mounted mine on the core support under where the battery used to be and use a stock cover. It's easy to get to there. I guess if you don't have to pull it a lot it would clean up the engine bay but I choose to ste my engine rearward for better weight distribution...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 02-23-2016, 05:19 PM   #8
Chris Coufal
I mounted mine behind the dash between the column and the radio.
Chris Coufal is offline   Reply With Quote
Old 02-23-2016, 07:13 PM   #9
72MARIO
72MARIO's Avatar
Chris. Was your harness a uncluttered stock lenght harness ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 02-25-2016, 02:36 AM   #10
Chris Coufal
Yep......stock harness that I had Ken W. make stand alone. It was not lengthened.
Old 03-03-2016, 03:39 PM   #11
Hart_Rod
Hart_Rod's Avatar
Passenger's side core support...
Hart_Rod is offline   Reply With Quote
Old 03-03-2016, 05:54 PM   #12
Willie Makeit
Willie Makeit's Avatar
Mine is similiar to Rob's above except its on the driver's side and the harness connectors enter from below. had numerous folks ask me where I had it hidden and it was right there in front of them.
Willie Makeit is offline   Reply With Quote
Old 03-03-2016, 06:24 PM   #13
michael bustamante
michael bustamante's Avatar
i need my harness modified as well, does he do this as a business?
1967custom
michael bustamante is offline   Reply With Quote
Old 03-23-2016, 01:47 AM   #14
Chris Coufal
Yep.....great guy to work with and takes time to explain everything and even give you all the part numbers you need to order for stuff like fuel setup.
http://www.standaloneharness.com/
Old 03-23-2016, 10:31 AM   #15
foamypirate
foamypirate's Avatar
Not the best picture, but I am using the Tejas Steelworks ECM mount with a small mod to my ECM mounting (longer standoffs) due to my harness routing.
foamypirate is offline   Reply With Quote
