hillbilly
65 c10 sway bar help needed
I just bought a sway bar off of a 79 c30. I bought the cpp brackets for lowered trucks. Im trying to locate the cpp brackets using txfirefighters method,but i think his thread is for a 67-72 truck. Im not sure what to go by?
-1962 C-10 |
hillbilly
Re: 65 c10 sway bar help needed
Here i am holding the cpp bracket up to the frame. This is where it needs to be if i put the sway bar ends flush with the backside of the bushings on the control arms.
-1962 C-10 |
Great Upgrade!
I started kind of back to front. I attached the ends to the A arms first and the then swung it up to the frame. After attaching the frame bushings, it was easy to mark the locations to drill the holes. I would play with it alot before drilling any holes. Good Luck! |
hillbilly
I found this in the faq but its for a ece setup.
http://www.hotrod.com/how-to/chassis...y-bar-install/ And this is the pic showing the first hole location It looks like 3" on the dot
-1962 C-10 |
#5 | |
hillbilly
-1962 C-10 |
#6 | |
It's been a few years but I remember about 1/2" to 1".
I do recall that the first time I tried I put jack stands under the frame and the wheels hung free. I could not get the sway bar any where close. The second attempt, I drove up on a set of rams and it nearly bolted itself on. |
