Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-25-2016, 10:16 AM   #26
vin63
It's Better With Nitro
vin63's Avatar
Re: How far "off" can a chassis be?
Originally Posted by team39763 View Post
...Why wouldn't the design work out well? I thought the x was stronger than straight bars?
Read the section (4-11) on roll cage requirements very carefully, so that you don't run into any issues after the fact (particularly the illustrations that note the tubing requirements and for the main hoop support bars). There is also a section specifically on pick up trucks, that I've brought up on this forum whenever someone asks about eliminating the rearward bars from the main hoop.
http://www.nhra.com/UserFiles/file/G...egulations.pdf
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
