Garage Queen Material
help a brotha out!
all i got left to get is:
carb headers elec. fans alternator i'm SO close! of course i could reuse my headers i had, but i would rather get the new shortie ones now. |
LED King
I've heard good about Doug Thorlys headers. You want shorties? Why?
Carb - Q-Jet! Edlebrock??? Electric fans - Spal - what company makes a bolt on 2 fan+shroud setup for our trucks (I know it was mega expensive)? Alternator - Powermaster 140amp one wire
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
carb- ??? dont know yet :/
fans: hayden 14" dual fans alternator:??? possibly jegs 100amp 1 wire??? headers: hedman elite shortie headers i want shorties because my trucks old headers came down way to low |
Professional Grade
I would go with longtube Nova headers myself, don't loose any flow, and they tuck up in the frame rails really nice
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Chevy 1967-81 Camaro, 1968-79 Nova, 1964-87 Chevelle/El Camino, 1971-91 Chevy Full-Size, 1970-77 Monte Carlo w/o A.I.R.
500-68608 those are the ones i'm getting. unlike the dynomax shorties, the hedman ones have 1 5/8th tubes and the dynomax have 1 1/2 |
Edelbrock 1904 for the carb, dont mess with an Eddy square bore if you want to make power. look for headers with at least 1 5/8" primaries, i dont see a real need for 1 3/4 primaries, but if you wanted to go that route, Heddman Hussler headers for a 67-69 Camaro will fit with slight mods and a custom trans crossmember (i have measurements for a custom crossmember if you'd like i can scan them and send them your way)
the only thing i'm pretty much undecided on is the carb, and i'm leaning towards a holley 750 vac.
Right turn Clyde
With that setup I think a stage 2-3 Jet Q-jet would be better over the edelbrock.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Holleys suck! QJet all the way! nothing like getting power AND milage from the same carb.
Thorley Tri-Y's make CRAZY power!
Just bolt all of your old stuff back on to get it in there and get it fired up and running. Then start buying allof the stuff you want. That's what I did. Go the cheap route to get it running and then buy a little here and a little there.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
I'm back with 2nd truck!
Get a Edelbrock 1406 and Smile
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
You get what you pay for
![]() Join Date: Dec 1999
Q-jets are not hard to tune. Why can't I convince you guys of this.
![]() Jet sells Q-jets with all the tuning already done. They have different stages according to your cam/engine combo. A simple bolt and go. About all they are left to do is adjust the IM screws. Cheaper than the 1904's. This is the way for a carb novice to go. I wouldn't swap my tuned by me 1904 for 5 1406's. Nothing better than the economy or power of a well tuned Q-jet. As for a Holley. Bah hum bug. It's made for the strip. Not a street carb at all IMO. Sure, easy to make adjustments to them, but come on folks. Them things love gas too much for me. If I've said it once, I've said it a thousand times. No, and I repeat, no carb will give you the the combination of fuel economy and power like a well tuned Q-jet. They have received a bad rep from people not in the know. You guys keep buying them square bore carbs. I'll stick with a tried and true carb.
Mike 1985 Chevy C-10 |
mike, what about a thermoquad? its essentially the same carb isnt it?
#15 |
Junk. Bigger cfm and all, but it's got a plastic throttle body. They will make some massive power, but don't last very long before they are totally worn out.
#16 | |
DAMN, I love Big Blocks!
*EDIT* In fact, I spotted an NOS thermoquad on e-ghay, set up with electric choke and chevy linkage (the Thermoquad "performance" model). I bid HIGH on that sucker to mount on my new 454, but i'll be damned if I didn't get sniped in the last 5 seconds. ![]() ![]()
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() Last edited by 76HighSierra; 03-06-2004 at 12:28 AM. |
#17 |
gas milage isnt a huge concern of mine.
i'm thinking of possibly getting a newer truck as a daily driver after graduation |
#18 |
Project92 SWB stepside
If your wanting all the power you can get from this motor I would scrap the Edelbrock carb idea. Great for a driver but not performance in my opinion.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
#19 |
i would put 5 stromberg carbs on it and strap a box fan to the radiator with zip ties.
i figure since you have already got people telling you to do 10 different things i might as well make up another idea.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#20 |
We're not telling what to do. We're telling him what we would do or have done. Besides, he can't seem to make up his own mind anyway.
Kids. What in the world are you going to do with them? ![]() |
#21 |
its only hard to decide on the darn carb.
#22 |
people can go on as much as they want about this carb does this and that one does that. but you really AREN'T going to get the best performance out of ANY carb that you buy unless you learn how to tinker with it. so i say buy what ever carb you want and familiarize (sp?) yourself with it. do some reading and some testing and you will be able to figure it out
#23 | |
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
#24 | |
