Lokar billet brake Pedal 1967-72 c10 defective ? What do you guys think?
I purchased a Lokar billet Pedal for 1967-72 c10. The pedal was sent directly from the factory. It appears to be missing two bolts and two nuts, but I am not sure if it is suppose to be like this. Is this defective? Would you guys return this item? Have any of you guys bought one like this one? I'm not please with quality as it seems there are two bolts and nuts missing. What do you guys think.
Thanks in advance. |
Old member
I just got mine form Jegs. It came with all 4 screws and nuts. The directions state only using 2 of them. I used all 4.
Go to Lowes and buy 2 more S/S screws & nuts and be done. I love the look of mine. Instructions for install. Step 3: Each Lokar aluminum cover has four mounting holes. This is to accommodate several applications. Typically only two mounting holes are used per installation. Choose the mounting holes that will not interfere with the pedal arm. If using two holes, be certain that they are diagonal from each other. We recommend using a 3/16" transfer punch to accurately mark the holes. The marks must be centered in the holes on the Lokar aluminum cover. Here is the link to the instructions. ![]() http://www.lokar.com/downloads/pdf-i...h-instruct.pdf
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Lokar billet brake Pedal 1967-72 c10 defective ? What do you guys think?
Thank you for response. I don't know why they drilled four holes. On was not drilled correctly.
Old member
I ordered the e brake one also to add. I'll have the whole look once it arrives. I like that brake pedal cover. It looks like a factory disc brake pedal now. that old pedal has looked out of place ever since I went to a automatic.
I think I am going to buy the hand brake pedal too.
I bought the covers for my stock pedals so they would match when I installed the Lokar gas pedal. The instructions said to only use 2 bolts kitty-corner to each other. I would guess their complete pedals only use the 2 as well.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
