Old 03-28-2016, 03:16 AM   #1
F.A.A.benny
Re: Has anyone disassembled their heater box?
Originally Posted by In The Ten Ring View Post
The flapper on mine is held by a rivet. Now it turns on a rod, but the rod is attached to a pivot and that is held by a rivet.
I do not have a pic and cannot get one for a few days a least.
If you drill out that rivet, the pivot will simply come off, leaving behind the rod. The rod will not come off if you remove that rivet. The rod goes through the bottom of the heater box, going through the slots of the flapper and finally exiting out the top of the heater box.. Look at it a little closer. You'll see what I'm talking about.
F.A.A.benny is offline   Reply With Quote
