03-24-2016, 04:18 PM | #1 |
Headers
Im looking for headers for my 1985 chevy c10 lowered 5.5" in the front with a 1985 350 bored 40 over with 96-up stock vortec heads. I need a set of headers that will fit between the block and frame and also i can not have the header sit below the frame due to the truck being so low and also i have a cpp transmission crossmember i have installed and i wanna avoid hitting that so im going to have the exhaust go up and over that crossmember, could you give me some suggestions and part numbers to go with for my application? Pics too!!
Thanks!! |
03-24-2016, 06:12 PM | #2 |
Diggin The SquareLife
Re: Headers
Patriot clippster headers
03-25-2016, 12:45 AM | #3 |
At the body shop.
Re: Headers
Small block?
These http://m.summitracing.com/parts/pte-h8021-1 Or these, will need a double hump x member. http://m.summitracing.com/parts/dou-d310-b
" That didnt make it any newer " " Dont antique the equipment " |
03-25-2016, 08:39 AM | #4 |
Re: Headers
If I recall (SB) 350 most long tube header the driver side is lower( drop lower then other side).
Not sure 1990 up long tube header now days. But you may need to make your own to custom long tube header. Or use shorty headers. Or buy set headers you like, cut them change to your needs.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
03-25-2016, 09:10 AM | #5 |
Re: Headers
will a gasket that has the round holes work on my heads cause i have the vortec heads and my ports are square with a radius corner cause im not sure? pic below! or will i need a different header? Thanks!!
[IMG][/IMG] Last edited by FB85C10; 03-25-2016 at 09:17 AM. |
03-25-2016, 11:48 AM | #6 |
Re: Headers
OBX 92 Camaro long tube headers. They stay above the frame and clear everything in the engine bay.
.....__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
03-25-2016, 12:52 PM | #7 |
At the body shop.
Re: Headers
The long tubes are a d port, they're on my truck with dart heads.
Square port angle plug. Fit and clearance is great.
03-25-2016, 02:39 PM | #8 |
Re: Headers
03-26-2016, 07:48 PM | #9 | |
Re: Headers
http://www.jegs.com/i/Hedman/500/68460/10002/-1 im looking for a set of headers 77 C10 small block. i have full length ones now but like FB85C10 im looking for something to stay above the frame. mine come down below the frame and at a downward angle. they are old and i have no idea what brand they are or what they are from i really dont want to spend 300 or 400 bucks on a set |
03-26-2016, 08:21 PM | #10 |
Re: Headers
I posted whatbi have on mine lol guess nobody wants shortys lol
03-26-2016, 09:05 PM | #11 |
Re: Headers
i know i dont want to pay that price lol
i just want something to help clear the crossmember so i can lower the truck |
03-26-2016, 10:39 PM | #12 | |
Re: Headers
I'm not sure of other brands, but I'm using these
03-27-2016, 10:32 AM | #13 | |
Re: Headers
03-27-2016, 11:04 AM | #14 |
Re: Headers
So i found uncoated Clippsters for $200
http://www.summitracing.com/parts/pt...del/c10-pickup these might work but i would really like headers that exit level with the frame instead of at a downward angle. like longtubes that are 4 inches shorter to go above the crossmember http://www.jegs.com/i/Hedman/500/68460/10002/-1 these might be the ticket Last edited by TrailerTrash; 03-27-2016 at 11:18 AM. |
03-27-2016, 04:34 PM | #15 |
Re: Headers
03-28-2016, 09:12 AM | #16 |
Re: Headers
those look perfect
03-28-2016, 09:30 AM | #17 |
Re: Headers
I forgot to mention they do run very close to my 4l80e pan but worked great with the 700r4.
03-28-2016, 09:45 AM | #18 | |
Re: Headers
When I researched this last year, the only person I spoke with who knew about the port height relative to the bolt holes, as well as the spark plug position was Sanderson dealer Century Performance Center in Reno, NV. He gave me a couple P/Ns that would work, but I can't find my notes. Another note on port height relative to header bolt holes: Exhaust gasses are most active at the top of the port. Just like a car going around a turn, the gasses don't want to change direction when they hit the turn, so they are forced to the outside of the turn -- the top of the port. So, the last thing you want to do is cover up even a tiny part of the port with a head gasket or header flange. I ended up using 96-2000 cast iron manifolds, and even had to grind them open at the top around .100". But since I plan to add headers someday, please let me know if you find some that fit. I'm learning that Doug's makes a high quality product, so I would probably call them too. Here you can see that OEM style gaskets cover up the top of a Vortec port. These are FelPro gaskets for a 96-up 5.7L engine, but I don't have the P/N.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 03-28-2016 at 10:09 AM. |
03-28-2016, 10:23 AM | #19 |
Re: Headers
Just noticed my Vortec heads' port shape is different than yours, and the bolt holes are a little lower than yours relative to port height. Are yours 064 castings?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
03-28-2016, 06:42 PM | #20 |
Re: Headers
I meant 062 castings, but this site won't let me edit my post.
