Old 10-09-2015, 01:29 AM   #201
geardrvn
Re: 48 5 Window air ride driver
Hey, nice work man! Looks good! I have rectangle stainless exhaust tips too I was going to run through the running boards like yours. I was curious how you mounted them? I was thinking about mounting mine directly to the running board so it doesnt rattle. Love these trucks on the ground!
"50 GMC 5.3l Vortec/bagged"
http://67-72chevytrucks.com/vboard/s...d.php?t=683537
geardrvn is offline   Reply With Quote
Old 10-09-2015, 07:07 AM   #202
oldnslow
Old Guy
oldnslow's Avatar
I mounted the rectangular tips directly to the U shaped tunnel that I welded into the running board. I added a 10"-12" section of stainless "flex" to allow some movement so nothing cracks. There is about a 3/16" gap between the tip and the notch in the running board to allow some air movement for cooling, it didn't discolor the primer, hopefully won't hurt the paint either. I am going to Locktite the four 1/4 -20 bolts that hold the tips on as they loosened a couple times last year.
oldnslow is offline   Reply With Quote
Old 10-09-2015, 07:12 AM   #203
oldnslow
Old Guy
oldnslow's Avatar
Here's a picture of the exhaust pipes, mufflers and tips after I painted them with Barbecue Grill black, not such a good idea, most flaked off, getting black ceramic coating next.
Old 10-09-2015, 08:21 AM   #204
4DSEVEN
4DSEVEN's Avatar
Truck looks great!
4DSEVEN is offline   Reply With Quote
Old 10-11-2015, 10:52 PM   #205
youngrodder
youngrodder's Avatar
Good idea about adding the flex piece. I learned the hard way after a cracked tailpipe mount, I went back and added a couple of flex joints.
Looks great
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 10-11-2015, 11:01 PM   #206
geardrvn
Awesome thanks! I made the u shape inserts and got my running boards cut this weekend. Hopefully get the exhaust on soon..
Old 03-13-2016, 06:41 PM   #207
oldnslow
Old Guy
oldnslow's Avatar
With the truck painted and the Illinois weather not so good for driving the truck, I'm trying to fix the things that didn't work properly and change some of the stuff I didn't like from the beginning. One of those was the carpet, the truck's red, the interior colors are red and white and the carpet was maroon. I ordered some bright red Daytona Weave (55 Chevy style) and had my interior guy Gary cut, sew and install it. I couldn't be happier, he called the color "hooker lipstick red" but I think it looks a ton better, here are before and after pictures.
Old 03-13-2016, 09:37 PM   #208
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Perfect!
ChuckDriver is offline   Reply With Quote
Old 03-14-2016, 01:09 AM   #209
wolffcub
wolffcub's Avatar
I like what you did with your remote brake reservoir. Can you post some closer pics and some pic of what you did from the underside?
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber.
If it aint broke I still try to fix it!
wolffcub is offline   Reply With Quote
Old 03-17-2016, 07:13 AM   #210
oldnslow
Old Guy
oldnslow's Avatar
I will post some pictures of the reservoirs top and bottom when I get in the garage this week end.
Old 03-23-2016, 08:58 PM   #211
oldnslow
Old Guy
oldnslow's Avatar
Here are a few pictures of the master cylinder reservoir from the top side, the pix from the bottom didn't come out well. I added a picture of the interior put back together with the new carpet. While the interior was apart I added two tweeters pointing up on top of the sub box, what an improvement! I think the component speakers in the kick panel are mounted so high that the tweeters are working better for ankles than ears. the new ones solved the problem.
Old 03-27-2016, 06:31 PM   #212
Donnie Lee
Beautiful truck inside & out, in your post #194 who makes the wheels you mounted?
Donnie Lee
Donnie Lee is offline   Reply With Quote
Old 03-27-2016, 06:48 PM   #213
Rude Dude
Rude Dude's Avatar
Beautiful Truck you did a great job!
Rude Dude is offline   Reply With Quote
Old 03-27-2016, 07:56 PM   #214
Advanced Design
Advanced Design's Avatar
Your truck came out spectacular!
Would you have a picture of the U shaped tunnel? Planning to go this route with my build and any help is greatly appreciated!
Advanced Design is offline   Reply With Quote
Old 03-28-2016, 05:52 PM   #215
oldnslow
Old Guy
oldnslow's Avatar
Donnie Lee, the wheels are Centerline Boulevard, I ordered them polished then decided they were a little shinier than I liked so I sanded them and applied Rust-oleum Dark Pewter "texture" paint to make them look a little more like cast wheels. AD I do not have any pictures of the exhaust tip tunnels (I was getting close to driving it and forgot to take pictures) But I made a crude drawing, basically I had them bent to a height that allowed me to use washers as spacers where I plug welded them to the running boards, they are fully welded to the outside and welded to the flange on the back side, I added the plug welds because the back side didn't have a lot of area to attach them to and even with the flex pipe, I was scared engine movement and vibration may crack a weld.
Take a look and let me know if you have any questions.
Old 03-28-2016, 05:57 PM   #216
oldnslow
Old Guy
oldnslow's Avatar
Sorry, I forgot the pictures.
Old 03-28-2016, 07:57 PM   #217
Advanced Design
Perfect explanation and drawing. Now I understand.
Thank you!
Old 03-28-2016, 10:17 PM   #218
Donnie Lee
Thank you for the wheel mfg., so you really do have one off custom wheels & they look great!
Donnie Lee
Old 03-29-2016, 10:49 PM   #219
youngrodder
The wheels look great. I really like how your truck has turned out.
Marc
Old 03-31-2016, 06:56 AM   #220
oldnslow
Old Guy
oldnslow's Avatar
Thanks, Marc, Going to Columbus this year?
Old 03-31-2016, 08:09 PM   #221
youngrodder
I believe so. My friends have the same block of rooms reserved at the host hotel....You?
Marc
Old 04-01-2016, 07:21 AM   #222
oldnslow
Old Guy
oldnslow's Avatar
Oh yeah, I love Columbus, its always fun, the hotel may be better than the show!
Old 04-01-2016, 08:15 AM   #223
Advanced Design
Speaking of Columbus, the truck in the middle of the promotional picture looks familiar.
https://www.good-guys.com/ggn-2016
Old 04-01-2016, 10:59 PM   #224
youngrodder
Doug..
Funny, good looking out. The red Camaro next to me is my friends car they built for a customer. That is who reserves the rooms all the time.
I will check the mail tomorrow for my royalty check. It must have been hung up in the mail.
Marc
Old 04-15-2016, 11:05 PM   #225
oldnslow
Old Guy
oldnslow's Avatar
Got to put some miles on the truck this evening.
