03-06-2004, 01:43 AM | #1 |
Life, Be In It.....
Opps, That stinks
03-06-2004, 01:45 AM | #2 |
its all about the +6 inches
Yikes...that WOULD suck huh?
03-06-2004, 01:49 AM | #3 |
Life, Be In It.....
My rear end locked up after towing it with no fluid, I am glad that did not happen to me.
03-06-2004, 01:52 AM | #4 |
maybe it had something to do with all those extra parts left over from the rebuild..????
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project Last edited by bigvinnie; 03-06-2004 at 01:55 AM. |
03-06-2004, 02:57 AM | #5 |
My son, my joy.
I guess you need more than two lug nuts per wheel, eh?
03-06-2004, 11:34 AM | #6 |
Does anyone know the story about what actually happened in this clip? The guy goes a few feet before he spits the wheels off, so what has blown up? I'm REALLY hoping that it wasn't just forgetting to tighten the lugs..
'70 C-10, mostly rust n' dust '74 BMW R90/6 "The quickest way to get yourself out of a hole, is to stop digging..." |
03-06-2004, 01:06 PM | #7 |
Did the wheel studs shear off? Never seen anything like that before. That really "bites"!
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. |
03-06-2004, 02:29 PM | #8 |
There is no doubt about it...it was cause by bad "Muffler Bearings."
HeHeHe!!! :p |
03-06-2004, 08:30 PM | #9 |
well it would be the C clips if the axles came out but seeing as its jut the wheels looks like it sheerd off
David M Proud Owner of A 67 C10 Shortfleet 350/350/3.73 |
