#2651 | |
![]() Join Date: Apr 2007
Re: PO has me PO'd
#2652 |
![]() Join Date: May 2006
Re: PO has me PO'd
![]() ![]() Things were progressing nicely for Saturday morning, when disaster happened....
#2653 |
Re: PO has me PO'd
![]() ![]() ![]() ![]() ![]() ![]() Luckily hydrotech supplies just enough extra hose and ferrules for a second attempt, I will be more careful this time
#2654 | |
60-66 Nut
Re: PO has me PO'd
Thanks for the info. I would have thought that, that application would have originally came with an integral reservoir, not a remote reservoir.
#2655 |
Re: PO has me PO'd
Yes are correct, the correct app. Would have had an integral reservoir. Mine has been moded
#2656 |
![]() Join Date: Nov 2007
Re: PO has me PO'd
Most people don't realize how tedious all the plumbing and wiring work is. Keep it up.
#2657 |
Re: PO has me PO'd
Thanks AJ for following along, you're rite about tedious. Set back with the kink kinda deflated my balloon.
Upstate NY right now, grandkids and an old wooden boat are taking up my time at the moment. My son has me working on the wiring harness, like I don't have enough of my own... Didn't post up any picks of my fish this year ![]()
#2658 |
Re: PO has me PO'd
#2659 |
Re: PO has me PO'd
Changed up a little from hydrotech, bango runs a little tighter than the 90 degree bend, also swivel. part # from pure choice is 11810
Also, tank should be here in a week from Petersen ![]()
#2660 |
Re: PO has me PO'd
Also started to work on my anti-freeze overflow tank, converted w/s washer tank, bracket bought from Roger Koop-aux. battery
[url=https://flic.kr/p/FgMvqS] ![]()
#2661 |
Re: PO has me PO'd
What has this build come to?!
#2662 |
Re: PO has me PO'd
![]() Happy Easter
#2663 |
Re: PO has me PO'd
Nice work Jaro! too bad about kinking the stainless braided line. Those aren't cheap either. I'm looking forward to seeing the rest of install on the Hyrotech boost setup
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
#2664 | |
Re: PO has me PO'd
Thanks for watching....
#2665 |
Re: PO has me PO'd
Installed the last of the high pressure hoses, swivel makes it much easier as you don't have to worry about the orientation of the fitting when assembled. I highly recommend using them on any hose application. Also, I use grease on the threads of the fitting when I swage it up
[url=https://flic.kr/p/FDtqoJ] ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-29-2016 at 10:24 AM. |
#2666 |
Re: PO has me PO'd
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-29-2016 at 10:25 AM. |
#2667 |
Re: PO has me PO'd
Tank came in from Petersen, have to build a plate to allow mounting using prop. Valve bolts
![]() Also, picked up my electric exhaust cut outs for the Camaro [url=https://flic.kr/p/FKmzzB] ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-31-2016 at 01:01 PM. |
#2668 |
Re: PO has me PO'd
Mocked up my tank, 2 1/4" 6061 x1/2" will be in today from mc master Carr.
![]() Now I can work on my return hoses and supply to pump
#2669 |
Re: PO has me PO'd
Ordered aluminum 4 pm, on my doorstep 10am, nice pulls up tight against a square flat and the two bosses for the bolts. Just need to buy 1/4" longer bolts
#2670 |
Re: PO has me PO'd
Dropped the radiator off at the welders shop, had to enlarge the outlet to 1 3/4", since that was the inlet size of my electric water pump. He also put a bead on the tube with his roller. Now, I can start working on the cooling system again
One more line to hook up on the hydro boost -10 return line, parts s/b here Monday ![]() ![]()
#2671 |
Re: PO has me PO'd
Finished up the last of the return hoses -10, after you install the crimping nut/collar in soft jaws in your vise, make sure your wrench doesn't extend below the nut you are tightening, it will gall the collar if you are not careful. But, you can touch up with a magic marker
If I didn't mention before, lubricate the threads, I would hate to gall the threads halfway up the crimp This Russell pro classic II hose is much easier to use then braided stainless, b/c you can rotate fittings to get alignment after crimping is done ![]() ![]() Ok, off to the next mod. Probably mounting computers in glovebox
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-27-2016 at 07:12 AM. |
#2672 |
Re: PO has me PO'd
Had some time to source out some radiator hoses today, shop worker allowed me to check out his inventory. First pick was exactly right for my purpose, like was made for a 72 jimmy w/ an aluminum rad w/ a 1 3/4" outlet. Cut off about 5 inches from the 90 degree side and added a mandrel bent 45degree aluminum tubing, have to take the tubing back to my welder to have a bead put on it
#2673 |
Re: PO has me PO'd
Jim. Good write up on your power steering plumbing for me. I too am going to run that Hydratech unit and a remote fluid reservoir.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#2674 | |
Re: PO has me PO'd
Which m/c are you going to use? Remote tank is supposed to be no further away then 13" so keep that in mind Also, tell Jim you want a banjo fitting instead of the supplied fitting that comes with the kit
#2675 |
Re: PO has me PO'd
It's been a month Jim. What's new?
BR549 |
