Old 03-31-2016, 02:58 AM   #1
BigDan3131
BigDan3131's Avatar
Question Better Route?
So here's the deal, I found a 1972 Chevy 1 ton with dual rear tires that was a dump box/highway truck. Would it be easier to put a step side bed on it and widen the fenders or do a fleetside bed with fender extensions.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-31-2016, 05:11 AM   #2
SS Tim
SS Tim's Avatar
Re: Better Route?
A couple of problems to start with.
A C30 has a longer wheelbase than a typical C10 or 20 so the readily available 8' boxes come up short due to a longer cab to axle dimension. So you need to find a Longhorn or 9'stepside box to start with if you are trying to do this as stock as possible.
With a stock dual wheel axle, the outer tires are a little wider than a fleetside box. So a flare or creative tire/wheel sizing is needed to tuck them. The inner tire will clear the frame of course but the wells need to be extended inboard a lot.
On a stepside the outer fenders are slightly narrower than a fleetside making the tuck a little more dificult. A widened fender or fender to bed spacer is probably the best way to handle that and adding narrowed fleetside wheelhousing should give you the inner clearance needed.
Either way you end up really narrow between the wheelhousings like a mini truck and nothing fits.
There are other options of course like the typical scabbed on stepside fenders that usually IMHO look too wide and flat against a fleetside bed. You can also use a later wide track dually axle and just push everything outboard from the stock srw location and fender or flair to suit.
SS Tim is offline   Reply With Quote
Old 03-31-2016, 05:58 AM   #3
Re: Better Route?
The easiest thing to do is leave it as a dump truck and have something cool and useful
Old 03-31-2016, 11:22 AM   #4
waco
Re: Better Route?
Checkout project "Meet Homer" 3/16/2016. That might give you a new to look at the project you have in mind.
Andy
waco is offline   Reply With Quote
Old 03-31-2016, 02:38 PM   #5
BigDan3131
BigDan3131's Avatar
Re: Better Route?
Its a mini dump bed of about 4 feet with a big ugly utility box in front of that. Thanks for the answers I can fab up anything since custom painting means custom body work in some cases. I did a 56 International 4X4 dually with widened stepside fenders for a customer.
Old 03-31-2016, 05:40 PM   #6
cooperhw
cooperhw's Avatar
Re: Better Route?
I was faced with this exact same dilemma last year (see "Meet Homer" in projects and builds). I simply widened the bed header panels and tailgate. Tailgate was the worse part. Kinda cool finished product (at least Me and a few others thought so).
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 03-31-2016, 10:13 PM   #7
palallin
Re: Better Route?
Some years back, there was a pic of a tow truck on here that had this kind of axle set up, and there were step-fender extensions--some 4" to 6" wide--bolted between the fenders and the bedsides. Looked factory. The steps angled out to meet the wider fenders. At one time, I had that pic saved, but I think I have lost it over the years.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-31-2016, 10:40 PM   #8
SS Tim
SS Tim's Avatar
Re: Better Route?
Here it is ~4", really not an original idea. At one time Dodge used fender spacers on their stepside/utilines with a drw option.
Old 03-31-2016, 11:04 PM   #9
Boog
laying low
Boog's Avatar
Re: Better Route?
Build yourself a neat flatbed.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-01-2016, 12:20 AM   #10
swamp rat
swamp rat's Avatar
Re: Better Route?
Originally Posted by boog View Post
build yourself a neat flatbed.
^^x2^^
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-01-2016, 03:13 AM   #11
BigDan3131
BigDan3131's Avatar
Re: Better Route?
That's the other option, but knowing myself it would have everything but the kitchen sink welded on to it.
Old 04-01-2016, 07:33 AM   #12
67 chevelle
67 chevelle's Avatar
Re: Better Route?
Looks awesome
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-01-2016, 08:09 AM   #13
palallin
Re: Better Route?
Thanks for posting those pics, Tim!
Old 04-01-2016, 09:50 AM   #14
72kool
72kool's Avatar
Re: Better Route?
i never get tired of looking at homer. love that truck. i would go the route that cooper did.looks more correct imho
1972 GMC C20 Custom Camper 350/TH350
72kool is offline   Reply With Quote
