03-30-2016, 03:59 PM | #1 |
New gauge cluster problems
So I bought a gauge cluster with tach out of a 77 manual dump truck from Dave on here. My truck is also a 77 but is auto. Tried installing it today and ran into a few snags. Maybe some of you can help me. Everything as far as gauges seem to be working except temp, which I believe is grounding out somewhere, and the tach, which just needs a new plug for the ignition coil. The bigger issue is that none of my cluster lights seems to be working right. For instance the blinkers don't work anymore, but when I press the brake the right blinker dash light comes on. Only thing I can think of is that the circuit doesn't match up to my stock circuit on my old cluster and it's getting confused. Any help would be appreciated!
1977 GMC C15 355/350 |
03-30-2016, 05:59 PM | #2 |
Re: New gauge cluster problems
So I figured out that my original cluster was a late 77 model and the new one is a 76- early 77 model. So I know there are a few pins on the harness I need to change. I'm just not sure which ones. Any help out there? Thanks!
03-30-2016, 06:05 PM | #3 |
Sorry, but it sounds like your new gauges are a... cluster.
03-30-2016, 06:25 PM | #4 |
Normally, the difference between the early 76 vs. late 76 & 77 clusters only affects the warning/indicator lights at the bottom of the speedometer & tach. All of the other cluster lights stayed connected to the same pin numbers.
However, the clusters out of the larger medium duty trucks might have some variations that don't always correspond year for year with the pick-up truck clusters. Do both clusters have voltmeters and mechanical oil pressure gauges? If so, they should be compatible but you still might want to follow the traces on the backs of both clusters to see if they match up to the same pin-out or not. Also check the condition of the tach cluster's flexible printed circuit ... especially the "fingers" in the area where the connector plugs in. If those are tarnished or loose & curled, they might not be making good contact and that could be causing some issues. |
03-30-2016, 06:52 PM | #5 |
Yea they both have voltmeter and the mech oil pressure gauges. Would it be possible to use my old printed circuit and just move the new tach and small fuel gauge over to it?
03-30-2016, 08:21 PM | #6 |
I recently did a similar gauge swap on my 78. I took the tach and small fuel gauge out of the old cluster and put it in my stock one along with the ribbon. It was pretty much plug in and go for me.
http://67-72chevytrucks.com/vboard/s...d.php?t=702346 |
03-31-2016, 01:24 AM | #7 |
Thanks for the help! I've found some helpful information so far. Would going from a cluster with 4 warning lights (two each under the speedo and fuel gauge) to a cluster with 2 warning lights (one under speedo and one under tach) make a different in the printed circuit or harness?
03-31-2016, 02:23 PM | #8 | |||
And if you have a 4x4, you loose the spot for the "4 wheel lock" indicator light (which had it's own wired bulb socket and didn't make use of the printed circuit traces). |
03-31-2016, 03:15 PM | #9 |
Yes. I did this on my big truck cluster swap since the printed circuit was in tough shape. I just soldered three short wires to the fuel gauge spots on the circuit and the other ends to the push in metal connectors. It works fine.
04-01-2016, 09:46 PM | #10 |
UPDATE: So I narrowed my problem down to the brake wiring was grounding out my blinkers somehow. I'm not sure how, but I ended up fixing that issue and now my blinkers work fine. Yet when I turn my dash lights on my right dash light blinker comes on solid. When I turn the right blinker on it still blinks tho. Not that big of a deal though because everything is basically working properly.
