Old 03-31-2016, 05:19 PM   #1
akaupp
Crossmember swap with manual steering
Hey all, looking to get sixfo lower without bagging it. I've realized I need drop spindles, which also means disc brakes. I'm wondering if it would be better to do the complete crossmember swap for a later model or just get drop spindles for the stock suspension. I want to keep manual steering. It seems like everyone goes power steering with the crossmember swap.
Also, what would be the easiest way to bring the back down the additional 2.5"-3" to keep it level. I'm currently running TJ coils and 2" blocks. I know I'll have to modify the frame to clear the arms, relocate the upper spring mounts and change the track bar. Do I need to flip the front mounts for the arms?
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
akaupp is offline   Reply With Quote
Old 04-01-2016, 06:45 AM   #2
PGSigns
PGSigns's Avatar
Re: Crossmember swap with manual steering
So what is in the front now and how low is the truck? Pic would be good. And how much lower do you want to go?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-01-2016, 09:19 AM   #3
akaupp
1.5 coils cut in front, TJ springs and 2 inch blocks in the rear
I'd like to get down a couple more inches.
Aaron
1964 K10
1964 C10
1965 Suburban
2005 Yukon
Old 04-01-2016, 08:10 PM   #4
PGSigns
PGSigns's Avatar
That far down I would look into notching the crossmember. Getting two more inches down I think will put you a arms very close to the ground.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-02-2016, 10:48 AM   #5
63burban
Chevy addict
Looks good now
63burban is offline   Reply With Quote
