Closed Thread
Old 03-31-2016, 09:06 PM   #3476
mud.man.rj
mud.man.rj's Avatar
Re: What did you do to your truck today? Chapter II
Not a big Toyota fan compared to old iron but like the idea, perfect powertrain that's bullet proof compared to American built and cool old style Gm body, thumbs up, hope it all works out. I like different projects that take a thinker to build.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 04-01-2016, 07:57 AM   #3477
Mator
Mator's Avatar
Well one more task down. Got the new seat covers installed. Thanks to Rick's Custom Upholstery. Came out really nice.
Mator is offline
Old 04-01-2016, 09:27 PM   #3478
Possmguts
Possmguts's Avatar
Nice!.. How do you like the one piece windows? I'm struggling with buying a kit from a guy that didn't use it...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 04-02-2016, 12:59 PM   #3479
68 Chevyota
Originally Posted by kilrcady View Post
buy American
I did! Both of them built right here in our States!
And thank you Don "Ole dollar", I'll post pics soon!
I would rather have a free bottle in front of me than a prefrontal lobotomy!!!!
68 Chevyota is offline
Old 04-02-2016, 11:02 PM   #3480
Possmguts
Possmguts's Avatar
Got started on the patching of the front of the hood today... hope to get the rest of the metal work done tomorrow and get started on the finish work. About tired of screwing with this hood...
Old 04-02-2016, 11:21 PM   #3481
c10ss69
c10ss69's Avatar
I was able to get some metal on the truck today, doors, inner fenders, fenders and grill along with a few trim pieces.
c10ss69 is offline
Old 04-03-2016, 12:16 AM   #3482
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Pulling wire mode today. Next up is score some hose line to see if the windshield washer system works. I'd like to see what I've got before I remove the LH dash panel components. Since I've owned this (1989) its never been hooked up, including a missing bottle. But it makes noise when I trigger it. I noticed the jets might be a bit clogged, could be why they disconnected. Will find out soon enough. 70/30 it works.
All new to me...........This is pretty cool. I've managed to avoid the windows and door latches so far (ha!). But I'll soon run out of parts to remove as I keep her running. Speak of, safe to assume I can remove the entire emergency brake system and still have brakes? Believe it or not, I've never even done a brake job outside a master cylinder and bleeding brakes...........Meanwhile, I'm taking this down to nuts and bolts.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 04-03-2016, 01:12 AM   #3483
66clow
66clow's Avatar
Got the bumper on today, she's smiling.
66clow is offline
Old 04-03-2016, 01:27 AM   #3484
71CHEVYSHORTBED402
Looks perfect. Let me know if I'm off base, but it seems the best way is to mount the inside of the bumper first, snug, not tight............line up the outer brackets, then tighten it all down.
Have to admit I butchered my rear bumper along time ago. Something wasn't right. When I tightened it down the brackets bent the bumper in places (whoops). Can't/won't happen again. I figure the brackets weren't positioned right.
Tony
Old 04-03-2016, 01:40 AM   #3485
66clow
66clow's Avatar
I mounted the small brackets first on the frame ends and then the bumper to those. Then the outer brackets. Everything loosely until I had all the bolts in.had to trim the left bracket due to the power steering box.
66clow is offline
Old 04-03-2016, 02:06 AM   #3486
71CHEVYSHORTBED402
Thanks for the info. Looks great.
Tony
Old 04-03-2016, 08:06 PM   #3487
djeCST
djeCST's Avatar
Got my dash painted today. Now I can install it and start on the wiring, which is what I was planning on doing before I realized the dash needed to be replaced. One step forward.....
Dennis
'70 CST/10
'55 Bel Air wagon
djeCST is offline
Old 04-03-2016, 09:12 PM   #3488
CST10
CST10's Avatar
Installed a new adjustable vacuum advance and set the timing on the 462CI BB in ol Samson today.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 04-03-2016, 09:20 PM   #3489
71CHEVYSHORTBED402
Well, I'm currently in "ID that wire" mode for under the hood. Honestly, those who altered some things did a sloppy job, so I'm rebutting a few lines so they route correctly, even though its all going to be pulled and replaced. I'll have plenty good questions about what's correct Vs what's wrong................Will save that until after I ID what goes to what and where.
On a side note, the more "exposure" the more I realize there's really not much to the wiring. At least not on these trucks. That said, I haven't dove into the LH dash panel yet.
Tony
Old 04-03-2016, 10:03 PM   #3490
Possmguts
Possmguts's Avatar
They are pretty straight forward and simple for the most part... I look under the hoods of new cars and trucks and run away in fear...
But I say its simple before I get to that point myself... Im sure there will be even less hair on my head when it all done...
Old 04-03-2016, 10:27 PM   #3491
AKC
AKC's Avatar
New door seals...
'Anela - AKC's 1968 C30 1T Flattie
"Trouble Rides A Fast Horse..."
AKC is offline
Old 04-03-2016, 11:02 PM   #3492
OregonNed
OregonNed's Avatar
More progress completed on the wood for the bed today. Routing and final sanding done - ready to apply the stain. Going for a reddish brown final color.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-03-2016, 11:07 PM   #3493
toolboxchev
Took it catching today, released a 18lb spring chinook native and released.
46 years and still working the pasture over.
toolboxchev is offline
Old 04-04-2016, 07:55 AM   #3494
Mator
Mator's Avatar
Smile Re: What did you do to your truck today? Chapter II
I like it. I haven't had any problems besides forgetting to glues the seal in. My wind wings were rusted out and the one piece window kit cost me less then buying a new set of wings so I saved money in the long run. And I can always switch back if needed. Thanks
Mator is offline
Old 04-05-2016, 12:51 AM   #3495
68 Stepper
Attempted to start my new engine, leaked gass all over the garage floor, will try again tomorrow!
68 Stepper is offline
Old 04-05-2016, 01:00 AM   #3496
Bomp
Bomp's Avatar
Hauled some parts home.
Getting ready to dive in on some fender repair.
Bomp is offline
Old 04-05-2016, 07:27 AM   #3497
ksshane
ksshane's Avatar
replaced the rubber grommet around my gas tank filler tube. Not near as bad as I thought it was going to be
71 swb 350/4sp manual 5/7 static drop
ksshane is offline
Old 04-05-2016, 08:46 AM   #3498
snipescastle2
snipescastle2's Avatar
Talking Re: What did you do to your truck today? Chapter II
How are you attaching your dash asides from the three bolts on either side, I assume you have left a portion of the sheet metal bare to "spot weld" it to the cowl section... Surprised you didn't paint that in the cab.
Have a good one,
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline
Old 04-05-2016, 02:20 PM   #3499
OregonNed
OregonNed's Avatar
Minor upgrade last night. Lost the rusty chrome cover and installed this stock restore. New gear oil and found out I have 3:08 gearing
Old 04-05-2016, 04:15 PM   #3500
tlman
doors fitted waiting for the good fenders and hood
tlman is offline
Closed Thread
