03-24-2014, 12:35 PM | #1 |
Porterbuilt Front Stage 1 Install.
Seems alot of people ask about installing a Porterbuilt Stage 1 front bag kit so I thought I'd post pictures of my install. I took lots and lots of pictures so it will be more than one post. I'm not an expert photographer or installer but it will give you a general ideal. I'm starting out with the springs and spindles removed. I had replaced my ball joints earlier and also redid my control arm shafts, so I'm starting with a clean slate . This was installed on a 68 c10 so if you have a different year it may vary a little. Here goes....... Hope you don't mind Nate
68 Chevy Short Stepside 250, 3 on tree |
03-24-2014, 12:42 PM | #2 |
Re: Porterbuilt Front Stage 1 Install.
Now that the bumpstop is gone , time to remove the upper shock mount.
03-24-2014, 12:46 PM | #3 |
Now I'm going to drill my crossmember for the upper bag plate.
03-24-2014, 12:49 PM | #4 |
I drilled a hole in the crossmember to run my air line.
03-24-2014, 12:53 PM | #5 |
I mounted the air bags to the upper plate and lower cup
03-24-2014, 12:56 PM | #6 |
Looking forward to more.
03-24-2014, 12:58 PM | #7 |
Mounting the bags
03-24-2014, 01:01 PM | #8 |
When you go to mount the drivers side upper shock mount you may run into this
03-24-2014, 01:05 PM | #9 |
I'm waiting on my spindles before I install the shocks but I'll post pictures when I install them. There are several threads you can search and reference before you install your front air bags. Here's a nice chart that shows the different hieghts with the different components. http://67-72chevytrucks.com/vboard/s...d.php?t=609897 The Porterbuilt kit is very nice and everything is labeled nicely, another big plus is Porterbuilt will answer any question you have.
68 Chevy Short Stepside 250, 3 on tree Last edited by 1moretime; 03-24-2014 at 01:11 PM. |
03-24-2014, 01:22 PM | #10 |
No I don't work for PorterBuilt but I'd sure like to. Think they could pay me in crossmembers.
03-24-2014, 02:08 PM | #11 |
Great info. Thank you. I'm hoping to be tackling mine when I take a vacation in 2 weeks.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
03-24-2014, 02:42 PM | #12 |
Very nice on the detail of the install, looking forward to the rest...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
03-24-2014, 09:07 PM | #13 |
where was this thread about two mounts ago? it sure does bring back memories. I want to add two notes things, test your bags, lines & fittings, to make sure they hold air pressure. my front bags wouldn't hold air for more than a few hours. I had to redo everything. also if you are running stock rally wheels, grinding of the lower control arm, around the ball joint area, may be necessary. larger diameter wheels makes this concern, grinding of the control arm, disappear. I am waiting until I can afford a nice pair of wheels b4 I run the streets of Miami. good luck to all. 1moretime, I'm gonna watch this thread. I wanna see your finished product.
03-24-2014, 10:05 PM | #14 |
Great write up, and thanks for sharing!
03-25-2014, 12:47 PM | #15 |
68 C 10
Great info in here thank for taking the time to write it up
Kevin "Life is Hard But its Harder when your Stupid" John Wayne 68 C10 70 C20 http://67-72chevytrucks.com/vboard/s....php?t=602326# |
03-25-2014, 11:48 PM | #16 |
Man i wish i had this when i installed mine, great job!
03-28-2014, 07:43 PM | #17 |
Got my drop spindles on and installed the shocks. Here's the shock mounting sequence.
03-28-2014, 07:46 PM | #18 |
More pictures of the bottom shock mount.
03-28-2014, 07:49 PM | #19 |
TIme for the top shock mount.
08-17-2014, 12:24 AM | #20 |
So does the bottom cup just sit in the recess of the lower control arm?
08-17-2014, 06:58 AM | #21 |
Yes
09-16-2014, 12:04 AM | #22 |
Great job!! Going to make my install alot easier.
09-18-2014, 06:24 PM | #23 |
Dumb question, never bagged one of these trucks but are shorter shocks/relocated a must or will stock?
Will the stock hold you up? |
04-03-2016, 05:45 AM | #24 |
WOW, very informative write up. What drop kit/spindles are you actually using??
04-03-2016, 08:29 AM | #25 |
Edit::: I read thru the actual build thread also and see that you have McG spindles.
Brooks -- South Louisiana 2004 Tahoe, DD Currently on the prowl for that right C10 project https://www.facebook.com/brooks.landry.1 IG : brolandry |
