Old 02-21-2016, 08:14 PM   #1
400/400
'87 TBI fuse issue
Blew a fuse in my '87 with TBI 350 today. While slowing to an intersection the truck stalled. It would crank but not fire. Listened for the fuel pump (electric in the tank) and couldn't hear it. Started checking fuses and found the ECM B fuse was blown. Replaced it and she fired right up. About 10 miles down the road it blew again. So I towed it home.
So the question is, would a bad fuel pump cause that fuse to blow? Or suggestions on where to start looking. What all does the ECM B fuse power? The pump was replace 5-6 years ago. I think the fuel pump is run through a relay on the fire wall.
Any suggestions are appreciated. Thanks in advance.
Also below is a pic of the manual. The ECM B fuse is at the lower left above the mounting hole.
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 02-22-2016, 01:06 AM   #2
Front Range
Front Range's Avatar
Re: '87 TBI fuse issue
Quick internet search brought up a few that might help. Sounds like a short in the wiring on the way to the pump, or the pump.
http://www.astrosafari.com/viewtopic.php?f=4&t=4746
http://www.justanswer.com/chevy/49ld...own-truck.html
http://www.s10forum.com/forum/f135/e...lowing-411116/
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 02-22-2016, 06:44 AM   #3
chengny
chengny's Avatar
Here is a wiring diagram for the fuel pump/FPR circuit:
And a couple of pages dealing with a Code 54 (low voltage condition in the FPR circuit). You're probably not throwing a code but the diagnostic may be useful:
As to the location of the oil pressure switch used in the fuel pump circuit - it may be either down by the oil filter or in the usual spot (behind the distributor). IDK these engines very well. If it exists, the oil pressure switch above the filter looks like this. Due to it's location, it may be a good place to start checking for wiring issues:
chengny is offline   Reply With Quote
Old 02-22-2016, 09:47 AM   #4
JW76
JW76's Avatar
Check the little diamond shaped plastic block on the firewall that the power wires run to. The tie between the two posts cracked on mine and was contacting the firewall and blowing the ECM B fuse. I chased the problem all over. I finally gave up and starting pull the harness out of the truck and noticed the issue.
JW76 is offline   Reply With Quote
Old 02-23-2016, 04:26 AM   #5
bealaddison
bealaddison's Avatar
My '87 Suburban did the same thing. I replaced the fuel pump and that was the end of it. More than likely you have a bad fuel pump.
'87 Chevy V20 Suburban
6in Lift, 37in Toyos/Nittos on 17x9 KMC Diesels
2009 Chevy Silverado 2500HD
6in Lift, 35in Toyos on 20x9 KMC Monsters
bealaddison is offline   Reply With Quote
Old 02-23-2016, 07:14 PM   #6
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: '87 TBI fuse issue
1st. thing I'd do is undo the connector at the frame that go's to the pump and sending unit and fab up a pig tail with a inline fuse and run 12v straight to the pump it's either gonna run or blow.
The power distribution block on the fire wall is easy enough to check first too!
Good luck.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 02-25-2016, 11:43 PM   #7
slug
slug's Avatar
Good luck.
Good idea. I did the same on my 87 when I got it to figure out which fuel pump was good and which was bad.
there is nothing better than cutting metal with fire.......except cutting metal with electricity!!!
slug is offline   Reply With Quote
Old 04-03-2016, 02:34 PM   #8
400/400
Thanks for the suggestions guys.
It took a few weeks before I had a chance to work on it. I think it's fixed. I started by turning the key to the run position without starting the truck to see if the fuse would blow without the pump running and it didn't.
So I figured replacing the pump was a good place to start as I think it was still the original. Haven't put too many miles on since replacing the pump but it hasn't blown the fuse yet.
