Old 01-27-2016, 01:41 AM   #801
RockTonka
RockTonka's Avatar
Re: 1958 Apache 38 Dually Dump Project
Originally Posted by lower50's View Post
Very Very nice work guys.
Thanks L50!
Originally Posted by Dan in Pasadena View Post
Maybe I missed it but did you weld the interior cab seams or are you just filling them with "kitty hair" filler or whatever?
Fully welded...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 01-27-2016, 09:35 AM   #802
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 01-27-2016, 10:22 AM   #803
FarmerSid
FarmerSid's Avatar
Nice! What about the seams in the door openings? Weld them up and then filler of some sort to smooth them out?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 01-27-2016, 12:30 PM   #804
Advanced Design
Advanced Design's Avatar
Looks like you guys were having a great time. Good progress!
Advanced Design is offline   Reply With Quote
Old 01-27-2016, 12:55 PM   #805
RockTonka
RockTonka's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
Appreciate that Kim!
Welding/seam sealer/glaze on fenders to cab and seam sealer/glaze on cab/door seams...so far.
Too much fun is had by all
My build thread
Old 01-27-2016, 02:23 PM   #806
ptc
ptc's Avatar
So that is going to be a "One-Piece" complete cab and front clip when you are all done. The only remove-able sheetmetal will be doors and hood pretty much?
I guess with all the welded joints you wont have to worry too much about bondo breakout with potholes and bumps and such....
Lookin great.... Lot-O-work!
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 01-27-2016, 07:52 PM   #807
RockTonka
RockTonka's Avatar
Yep, pretty much a 4 piece cab and front clip!
The entire assembly is fairly rigid...tying in the inner fenders to the firewall stiffened it up quite a bit, triangulation of sorts.
The frame is fairly rigid also, crossmembers, steps, and plating add to that.
All in all, I hope that there won't be much difference between chassis flex and body flex...and we're trying to minimize the amount of bondo also.
But, time will tell!
My build thread
Old 04-02-2016, 10:05 AM   #808
6BT 56
6BT 56's Avatar
Any updates on this one ? Just abt to go back and look up you gin pole lift . I seem to think I need one around the farm .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 04-04-2016, 01:00 AM   #809
RockTonka
RockTonka's Avatar
Not much to report...still trying to work through the smoothing/shaping stage.
Our buddy Scott has been busy with his life and we only have a few moments here and there to work on the 58. I wish we were more experienced with this stage of the build and could move forward on our own, but we need his help.
These pics look a lot like the older pics, but we are making some progress...doors are very close to where they need to be, body lines are being massaged together, and low spots and seams are disappearing.
My build thread
Old 04-04-2016, 01:19 AM   #810
Grizz1963
Grizz1963's Avatar
Morning Phil
Progress is progress.
My motor is back together now...... So bodywork etc can start soon too.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 04-04-2016, 08:35 AM   #811
Kim57
Kim57's Avatar
Every little bit helps.
Kim
My build thread
Old 07-11-2016, 12:08 AM   #812
6BT 56
6BT 56's Avatar
How's things going in your neck of the woods ? Making much headway ?
Old 07-11-2016, 07:34 AM   #813
dug224
dug224's Avatar
Logging in the manhours. Looks great. dug
dug224 is offline   Reply With Quote
Old 07-12-2016, 12:37 AM   #814
RockTonka
RockTonka's Avatar
We're doing well...keeping busy with everything but the 58! Scott has the truck at his shop now, hoping that will make it easier for him to work through the bodywork.
Thanks Dug! Progress has slowed a bit, but we'll get there eventually.
My build thread
Old 08-28-2016, 12:31 AM   #815
Tgubser
Just read through your build, awesome work! Love the detail going to be 1 sweet "tonner"!
Tgubser is offline   Reply With Quote
Old 08-31-2016, 12:42 AM   #816
RockTonka
RockTonka's Avatar
Thanks!...and welcome to the site, lot's of great people/builds/info here.
The cab is still at Scott's place. I spoke to him last week and he is trying to light a fire under it...we would like to have it back before the end of the year. I'm anxious to get back on it!!
My build thread
Old 01-19-2017, 10:18 PM   #817
RockTonka
RockTonka's Avatar
The cab's getting a little closer to being ready for primer. The doors and hood are locked down and the gaps are looking really good.
We're in final sanding with just a bit more glaze here and there...mainly in the engine bay and interior.
There will be more smoothing/sanding after primer, but it will be a huge step for me to have it one color.
My build thread
Old 01-20-2017, 10:06 AM   #818
Kim57
Kim57's Avatar
Looks good.
Love the holes in the hood.
Kim
My build thread
Old 01-20-2017, 10:05 PM   #819
Advanced Design
Good to see the update...truck is getting better and better.
Old 01-21-2017, 12:23 AM   #820
RockTonka
RockTonka's Avatar
Looks good.
Kim
Thanks Kim! I've been trying to keep tabs on your project...good to see ya back on it and moving forward. It's good to see the stage your at with the body (you and the truck )...the cab really looks good!!
Hey AD, thank ya!
My build thread
Old 01-23-2017, 03:21 AM   #821
RockTonka
RockTonka's Avatar
We've had a couple decent days of weather, so decided to get back on finishing the bedsides. I've been putting this off because I wasn't looking forward to all the sanding.
Anyway, spent half the weekend and got about a third of the bedsides done.
We are fine sanding the old sides back to fresh wood, floating some black paint onto them, sanding them back down to expose some grain, and then treating them with a Thompson water seal/stain.
My build thread
Old 01-23-2017, 01:00 PM   #822
Kim57
Kim57's Avatar
Wood looks real nice.
Kim
My build thread
Old 01-23-2017, 03:17 PM   #823
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
That looks awesome! I really like the touch on the wood work.
Ryan
1969 Chevy milk truck
Old 01-24-2017, 01:30 AM   #824
RockTonka
RockTonka's Avatar
Thanks y'all...it's nice to just get out and work on it a bit again.
My build thread
Old 01-26-2017, 02:02 AM   #825
RockTonka
RockTonka's Avatar
Passenger side bed wood done...
My build thread
