04-04-2016, 04:44 PM | #1 |
53 Cab Removal
Ok, so I made a 2x4 setup like seen here and mounted on my engine hoist. Trying to jack/raise cab off of frame. I removed the rear shackles. I removed the front two nuts under frame on front cab mounts.
My question is, are the front bolts threaded into the frame from the top also? I thought removing bottom nuts I could lift it up, but with nuts removed it seems like something is grabbing. The passenger side top bolt is so rounded and rusted would be a bi--- to remove. Any help here?
"All the best, Phil" My 53 IFS air bagged Upgrade Here One of my threads for this build... http://67-72chevytrucks.com/vboard/s...12#post7662512 |
04-04-2016, 06:28 PM | #2 |
Re: 53 Cab Removal
Front bolts are not threaded into the cab. Prob just stuck on there.
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
04-04-2016, 06:40 PM | #3 |
Re: 53 Cab Removal
Yes, thanks Sim..
When I tried jacking my cab with the 2x4 setup I made, it was tilting forward. I could not free it up. I put a secondary bolt halfway thru the nut, then screwed the nut onto the bolt, and using the bolt like a punch with a few shots with the mini sledge on each side I freed them. Cab is now swinging in the breeze!
04-04-2016, 06:43 PM | #4 |
Re: 53 Cab Removal
Sorry, tried posting pics from my iPad. It only uploaded the shot of my hand!
Missed 3 out of 5 swings!!!
04-04-2016, 06:55 PM | #5 |
Re: 53 Cab Removal
Holy Mackrel!
Cant believe you cant edit a post. I tried to remove that photo instantly! Any way, here's the culprit...
04-04-2016, 09:41 PM | #6 |
Re: 53 Cab Removal
Hey, your hand looks like mine. I'm left handed and every time I pick up a hammer my right hand tries to hide.
