72 grille install help
Purchased a new grille, new hardware kit, and new grille support brace from LMC Truck. Problem is the truck was not together when we bought it so I'm having to figure this stuff out by looking at pics and parts schematics. I have the actuall grille in, but can't figure out what hardware to use to connect the grille to the support bracket. Need to know what screw and clips go were and from which direction .
Up close pics would be great if anyone has any available Thanks in advance
2016 Silverado2005 GMC Sierra 2002 Chevy Slverado Extra Cab (youngest sons) 2009 GMC Denali (oldest sons) 2015 Lexus 250i (wifes) 1972 Chevy C10 LWB, 5.3 / 4L60e swap "COLOR OF MONEY" http://www.louisianaclassictruckclub.com |
Re: 72 grille install help
Bump
I just had mine apart. On mine the square inserts went through from the radiator side sandwiching the grill insert. Then used a small sheet metal type screw to expand the square piece. Like a drywall anchor. Hope this makes sense. I'll post a pic in a few.
![]() Join Date: Sep 2015
TTT will be having this same problems. If anyone has any pics please post them. Thanks!
I can see if I have any pictures of a grille installed shortly.
In the interim. I might as well post this to see if it helps: [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
[IMG]
[/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG]IMG]http://i63.tinypic.com/2q32fyw.jpg[/IMG][/IMG] This is off one of our dead trucks we haven't restored....my understanding is it was still factory on the front end...never been taken apart. Take that with a grain of salt...as I'm not 100% on that. |
I have a ton of pictures but I cannot upload any until I take my computer in to the shop and they straighten it out. I managed to get one of like 25 pics that I have on this thread.
The inner grill to outer grill and back to the front of the truck is pretty easy. The inner grill is held to the outer grill (I have a 1972 truck also) with a series of square "clips." You might can buy new ones at an auto supply store, I used my old ones. These push in. There is a small screw that also goes into the clips but I don't see what purpose those fill. The outer grill is riveted to the grill brackets, I screwed mine together with little pieces a member suggested, forgot what those are called. Found a pic! Ebay.com has these "rivet screws" or something. I forgot what size I bought. http://i.ebayimg.com/06/!B9mv+gQCWk~$(KGrHqEOKjsEzFffEK6BBM6U0k2T0!~~_35.JPG?set_id=8800005007 The grill brackets bolt to the outer fenders. You can sorta see where those go in this pic.....the computer just won't let me link the other pics I have on this. ![]() Just can't upload what I have, sorry. Last edited by In The Ten Ring; 01-28-2016 at 05:27 PM. |
thanks for the pics guys.....I have the inner grille in place, found out the problem was the PO had the wrong hood latch bolted to the core support, it was throwing everything off ! Ordering the correct hood latch and everything SHOULD line up !
Thanks for the help and the pics Wade
![]() Join Date: Oct 2015
Want to do this too, gotta find a grill first
http://67-72chevytrucks.com/vboard/s...ighlight=grill Rob |
![]() Join Date: Apr 2005
Great thread!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
| Bookmarks |
