![]() Join Date: Feb 2013
Recommend Me an HEI Dizzy
I have a couple of the Skip White HEI distributors. In two years the first one fried 2 ignition modules. I decided for the price to try a second one in my new 350, and on my way home from work last night doing 70 on the interstate the module started to flake out and the engine started to decell. I know it was the module because I have done this twice before. I was surprised today that it was not completely fried and that the truck started after cooling down.
Anyway I am thinking it is time to get a better unit. I am thinking about giving the GM Performance a try, but I thought it best to ask the collective knowledge here first. I do not need a racing dizzy, just something reliable for a 350 with an RV cam (summit 1102) Is there another I should be looking at? I am not apposed to spending if it means reliability. I also like the idea of an adjustable vacuum advance can, I plan to get my wideband O2 sensor hooked up and see what I can do to dial in the carb. |
![]() Join Date: Feb 2001
Re: Recommend Me an HEI Dizzy
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Who Changed This?
![]() Join Date: Jan 2013
I have a Mallory HEI that has been in service for 15 years. Never had a problem with it.
I bought a stock, direct replacement HEI for my small block 400 from NAPA.
No problems here. ![]()
1970 3/4 ton long box GMC !968 C10 short stepside (Papa's Old Lorry) 2006 2500 HD Silverado Duramax/Alison |
![]() Join Date: Apr 2012
My AC-Delco is 41 years old but had to be rebuilt about 5 years ago. So I guess it did give me a problem.
20' Daredevil (Ret)
![]() Join Date: May 2003
Been running a used GM HEI since the early Eighties without any problem. Well, I did install a new rotor back in the early Nineties.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
In my son's truck, the stock HEI kept eating modules and coils, I bought a new HEI from Summit a couple of years ago for around $90.00, haven't had a problem since
![]() Join Date: Dec 2006
I've had a Skip White in my 350 for maybe 12 years with no problem whatsoever.
What is your voltage to the Distrib? Cheaper modules apparently have no over-voltage protection. Read here; http://67-72chevytrucks.com/vboard/s...d.php?t=319969
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
Old member
Local junkyard. Buy the factory GM HEI and replace the module and your good to go.
Are just go buy it at the parts store but you will need a model and year. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I agree with the majority-Go Stock GM. Can't go wrong.
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
Old member
Mid 80's to 90's had them in just about everything GM made then.
Scrapper 1
If your going from points to HEI need to get that voltage drop block off your truck.When i put mine in I bought the engine harness from M&H wiring company 159.00 no Problems Stay away from Painless
![]() Join Date: Sep 2007
Have a rebuilt HEI in my '70 El Camino I rebuilt 15 years ago, no problems, also have a HEI in my '71 Cheyenne Super big block 402, no problems. Stay away from anything coming from China, or any other foreign made distributor , not worth the hassle with problems down the road. Stock G.M. HEI's are a dime a dozen, lots of upgrade parts available from MSD, ACCEL, MALLORY.
1971 Cheyenne Super C-20 402 4 speed 1970 El Camino L-48 350 1999 Chevy Z-71 Extended Cab 4x4 2000 Tahoe Z-71 2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator 1970 Chevelle, Malibu Sport Coupe 2007 Harley-Davidson FLHX Street Glide |
#15 |
Stock GM with Accel cap/coil....
#16 |
![]() Join Date: Apr 2016
#17 |
Shortbed club member
I have Skip White distributors in both of my trucks.
Haven't had a problem with either of them. Not a bad deal for less then 50$.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
#18 |
I would start by looking at your electrical system before I went and threw money at a new dizzy. HEI ignition modules do not like low voltage at all. Either intermittent or sustained low voltage. Low voltage will kill modules all day long. So check that you are not using the factory resistance wire for power, and check that you are providing your HEI a clean 12V source that does not fluctuate when electric fans kick on, or other power accessories are turned on. The best bet to get a clean 12V source is to tap directly into the battery, and use a relay with keyed power to close the circuit between the battery and HEI.
#19 | |
Thanks for the help all. I'm still reading/researching, trying to decide.
#20 |
I have owned a summit racing dizzy for over 10 years no issues.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
#21 |
I'd take a used American made HEI (though preferably new GM) over a new Chinese unit anyday. They seem to be nothing but problems.
Heck, I'd take a known-good used Chinese one over a potential jackpot new one!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
