Old 02-28-2016, 04:02 PM   #1
71swb4x4
71swb4x4's Avatar
What size fuel filler hose?
I bought fuel filler hose from Wes at Classic Heartbeat. I am trying to get this tank installed today and I can't get this hose on. I have struggled, warmed it, and struggled some more. The hose I received is 1 1/4". The fuel tank and steel fill tubes measure 1 3/8". Am I supposed to be able to stretch this over, or did I get the wrong size hose?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-28-2016, 04:36 PM   #2
Bigdav160
Bigdav160's Avatar
Re: What size fuel filler hose?
I would try some lube. But I'm with you. I thought the hose was closer to 1 1/2"
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-28-2016, 04:45 PM   #3
71swb4x4
71swb4x4's Avatar
I measured the old hoses, fuel tank inlet, steel 90 degree, and the bed filler tube, and all measure 1 3/8". I ordered some from fillernecksupply.com. After a little research it seems that Blazers used 1 3/8" up to 1981. I wouldn't take that as gospel, but that's what I have found so far in my research.
I hope I can install this fuel filler hose with the tank installed. I am going to try to hook all the rest up and see if I think I have enough room to install the large hose once it gets here. I didn't look forward to this project, and I don't want to drag it out anymore.
Old 02-28-2016, 06:31 PM   #4
hemi43
hemi43's Avatar
The hose is definitely 1 3/8". I had difficulty finding it, and even my jobber said they couldn't get it until I gave them a part number. A few days later I had it in my hand. If you're still having difficulty finding it, I'll try and dig up the receipt for the part #.
hemi43 is offline   Reply With Quote
Old 02-28-2016, 07:02 PM   #5
71swb4x4
71swb4x4's Avatar
I ordered some today online. Before that I stopped by the places open on Sunday.
I went to Advance Auto, no filler hose at all because it didn't come up when he looked up a 1971 Blazer on his computer. I didn't even bother wasting my breath. I went to Carquest and they actually tried to find it but their supplier couldn't get it. So then I ordered it online.
The tank is fully installed minus the filler. It looks like it should be pretty easy to install the filler hose even with the tank installed. I can't wait to have more than 2 gallons of fuel capacity!
Old 02-28-2016, 09:11 PM   #6
hemi43
hemi43's Avatar
Glad you got some. I found the receipt, and it was a Gates part#24702
Old 02-28-2016, 09:46 PM   #7
71swb4x4
71swb4x4's Avatar
I bet Carquest could have gotten it for me with that number. Hopefully this will help the next person.
Old 03-01-2016, 10:34 AM   #8
dirish
dirish's Avatar
GM part number 457516.
I found it at wheeler brothers Fleet.
Was 18$ for 2 foot.
dirish is offline   Reply With Quote
Old 04-06-2016, 09:51 AM   #9
Okie528
Okie528's Avatar
Hey guys,
I just ordered a new tank for my '72 Blazer (standard 21 gallon Counter part tank Kit) that all the online parts guys sell. I'm replacing a leaking aftermarket 37 Gallon tank that was installed in my truck in 1977, so I assume it will not have factory hoses for me to try to match. Based on the above thread I know I will need 1 3/8" hose (what length) and also if you all could tell me what other hoses I should order to install this tank. Also, the description of the tank says "Does not come with the original Blazer filler neck. Spout may need modifications." what modifications are they talking about? Any advise to make my install go smooth will be appreciated.
Thanks in advance.
Okie528 is offline   Reply With Quote
Old 04-06-2016, 12:31 PM   #10
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Originally Posted by Okie528 View Post
Hey guys,
Thanks in advance.
Okie,
The original blazer filler neck coming off the tank was longer and had bends to meet up with the filler neck that comes off the body. You only needed so much of the hose which was straight to connect the two. The new blazer tanks only have a neck that is about a couple inches long so now you have to either cut the old neck and weld it to the new tank or find a hose that has the right bend to make the angle of the tank and connect to the filler hose from the body.
I am looking at a modification that I think will work, once I verify it I will post it.
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-06-2016, 12:32 PM   #11
71meangreenc10
Have you spoken to Wes about this? He is usually on top of these issues.
Smitty
71 C30 Wrecker
Old 04-06-2016, 12:48 PM   #12
71meangreenc10
I have talked to Gates Product Support about what it takes to get this hose made. Currently looking at getting the angles and measurements to see if they already produce what we need and send me back a part number or what it will cost to make it.
Smitty
71 C30 Wrecker
Old 04-06-2016, 07:37 PM   #13
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
This is good to know, thanks for posting the info, folks! I hope to drop the tank out of my Jimmy soon and know the hoses will have to be cut.
DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 04-06-2016, 08:03 PM   #14
tjsblazer
tjsblazer's Avatar
Hey guys,
Thanks in advance.
Yes 1.375" filler hose and 0.500" for the overflow hose. I am unsure of the exact lengths of each off hand. The fill hose is around 12" and the overflow is likely around double that.
As far as the Inlet spout on the tank this is an issue for everyone. The aftermarket tanks typically just come with about a 3" long pipe sticking straight out. The factory had a U shape bent pipe that fit around the Body mount. One solution people use is to swap the filler inlet from a factory tank that is rusted out to the new aftermarket tank. Others come up with something they fabricate whether with metal or rubber fuel hose.
Either way you need to find a way to get it around the body mount. If it is the typical aftermarket tank it will be an interference point.
If you search this same forum for fuel tank you will likely see some threads on the Tank inlet issues on aftermarket tanks.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 04-06-2016, 08:05 PM   #15
jaros44sr
jaros44sr's Avatar
As stated above the hose is 1 3/8", got mine from filler neck supply. Problem with the replacement tanks is the filler neck is only a straight 2-3 inch piece, so you have to replace it with the original 2 or3 bends, that the original neck has, get it lined up with the hose, the hose can be straight as it only requires a slight bend to get it on the filler neck
Use tin snips to remove old filler neck, then you can safely remove solder with heat, and the 2 bolts holding it on to the old piece of tank that you removed with tin snips
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-06-2016, 08:09 PM   #16
tjsblazer
tjsblazer's Avatar
Here is a picture showing how the factory tank has a long bend in the Inlet pipe to get around the body mount. (looks like Jim and I posted about the same time on this issue). This picture is actually an aftermarket tank with a factory Inlet swapped.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 04-06-2016, 08:16 PM   #17
jaros44sr
jaros44sr's Avatar
Yeah Jeff, guess we were writing at the same time.
Pic. Of bends on page 88 of my build, I'm glad I'm past that point as it was a real PIA
SAFETY FIRST
AS usual, off topic
Jim
Old 04-06-2016, 09:18 PM   #18
71swb4x4
71swb4x4's Avatar
For a factory tank and neck you need an 8" piece to go up into the tub and a 12" piece to go over to the tank. With that aftermarket one you will need a little more than 12". I ordered soft wall, but I didn't find the hard wall until searching tonight. If I was ordering again I would definitely order hard wall.
Hard wall: http://www.fillernecksupply.com/1-3-...hose-per-inch/
Soft wall: http://www.fillernecksupply.com/1-3-...sold-per-inch/
Old 04-06-2016, 09:27 PM   #19
71swb4x4
71swb4x4's Avatar
Just to clarify, because this threw me for a loop at first, what he is saying here is that you cut the old tank with tin snips. Don't use the tin snips to cut the filler neck. Cut it out around the old filler neck. Then you can apply heat without any concern about a gas tank blowing up on you.
When I did this same thing years ago on my Jimmy, I filled the tank with water and heated it up. The old filler neck is soldered on and doesn't take a ton of heat to remove. The new filler neck I think is brazed on, it takes a ton of heat to get the new one off.
Old 04-06-2016, 10:25 PM   #20
jaros44sr
jaros44sr's Avatar
Thank you for clearing that up (obfuscation). My fingers move faster than my brain. Good catch, wouldn't want anyone getting hurt
Didn't know about the soft wall
SAFETY FIRST
AS usual, off topic
Jim
