Old 04-05-2016, 07:10 PM   #476
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Originally Posted by collin70k/20 View Post
I am going to admit your truck is probably my favorite in the 60-66 chevy forum area! You are definatly making some progress keep up the good work man!
Thanks very much!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-05-2016, 09:35 PM   #477
62stepside longbox
With lots of modifications to the cab support I finally got it welded in. The next step is to patch the floor above the support.
Old 04-05-2016, 09:35 PM   #478
62stepside longbox
From the inside
Old 04-06-2016, 10:06 PM   #479
62stepside longbox
Hit a big roadblock today. The bed is in the way of me doing the cab corner and there is more rust behind the bed
Old 04-06-2016, 10:09 PM   #480
62stepside longbox
So the bed is going to have to come off. At least it will give me a chance to straighten out the passenger bedside. Someone must have put something too wide in the bed
Old 04-06-2016, 10:13 PM   #481
62stepside longbox
The plywood was hiding the original bed wood which unfortunately is rotten but the bed strips are in incredible condition, not a single dent, just surface rust.
Old 04-06-2016, 10:15 PM   #482
62stepside longbox
And I got all the bed bolts out without breaking any. I should get the bed off tomorrow
Old 04-07-2016, 12:24 AM   #483
TJ's Chevy
TJ's Chevy's Avatar
Progress!
Old 04-07-2016, 07:57 PM   #484
62stepside longbox
Got some friends over to help me lift the bed off. Now it's really easy to work on stuff. I think I'll work on the gas tank as well since it's so easy to get to
Old 04-07-2016, 10:30 PM   #485
62stepside longbox
Got the gas tank mocked up, much easier without the bed on. I also got the sending unit installed, this was quite a bit of trouble as the tank did not come with a lock ring and I couldn't find one anywhere except the U.S. so I made one out of sheet metal.
Old 04-07-2016, 11:50 PM   #486
step65
Great progress and nice work.
step65 is offline   Reply With Quote
Old 04-08-2016, 12:49 AM   #487
62stepside longbox
Thank you very much
Old 04-08-2016, 03:37 PM   #488
AJCK87
Awesome work! Keep at it. I know what you mean about the patch panels, they never fit quite right. I did find that the repo rockers I got fit with only slight modification and look sharpe after install. I'm sure it's hit or miss between the brands
AJCK87 is offline   Reply With Quote
Old 04-08-2016, 06:44 PM   #489
62stepside longbox
Thanks! The rockers are the only decent patch panel in my opinion. They save time and only need little modifications. From now on I plan on building all my patch panels.
Old 04-09-2016, 11:29 PM   #490
62stepside longbox
Did some work on the cab support/cab corner today. Built the section that covers the cab support and gives the cab corner something to attach to. I also did some cleaning on the frame and ran my new aluminum fuel line and the wires for the sending unit
Old 04-09-2016, 11:38 PM   #491
TJ's Chevy
TJ's Chevy's Avatar
Nice work bud!
Old 04-09-2016, 11:59 PM   #492
62stepside longbox
Originally Posted by TJ's Chevy View Post
Nice work bud!
Thanks tj!
Old 04-10-2016, 12:10 AM   #493
namloc
namloc's Avatar
Great progress.Cool score on the Burb' hood.
The Snortin' Bull
namloc is offline   Reply With Quote
Old 04-10-2016, 12:22 AM   #494
62stepside longbox
Thanks! Yes the 60-61 gmc hoods are my favourite
Old 04-10-2016, 12:19 PM   #495
namloc
namloc's Avatar
Just A thought .When you get the hood make sure you get the latch parts.And the center support that has the catch portion.They are different and can be hard to find.
The Snortin' Bull
Old 04-10-2016, 12:33 PM   #496
65sub
65sub's Avatar
Looking good Nik. Your "build it yourself" attitude is awesome.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 04-10-2016, 10:39 PM   #497
62stepside longbox
Yes I'm getting the latch
Thanks Dale, when I'm done I'll definitely be able to say "built not bought"
Old 04-10-2016, 11:01 PM   #498
62stepside longbox
No pictures but today I got my sending unit working and did a little wiring to swap my generator for an alternator
Old 04-11-2016, 11:48 PM   #499
62stepside longbox
Did some work on the alternator brackets today. Used the bottom bracket from the generator that bolts to the block and drilled two new holes so the alternator could move forward and Line up with the pulleys. Then I welded on a tab in the middle with a hole drilled in it and left a little space so I can shim it to sit in the right spot.
Old 04-12-2016, 12:10 AM   #500
TJ's Chevy
TJ's Chevy's Avatar
Custom!
