Old 04-07-2016, 09:35 PM   #1
c10ss69
c10ss69's Avatar
Parking light help
My park lights work when my switch is in the park light position but go out when the headlights are on. Is this normal?
c10ss69 is offline   Reply With Quote
Old 04-07-2016, 10:02 PM   #2
firedemon
Re: Parking light help
my 67 is the same wondered myself must be normal
firedemon is offline   Reply With Quote
Old 04-08-2016, 02:02 AM   #3
Custom/20
Custom/20's Avatar
Judging by your name you have a 69 and if so then no yours should stay on with the headlights. I have a 69 and mine stay on. If I'm correct only 67 has it where the park lamps turn off when the headlights are on.
Custom/20 is offline   Reply With Quote
Old 04-08-2016, 07:22 AM   #4
c10ss69
c10ss69's Avatar
My truck is a 69 but I have a painless wiring harness, aftermarket headlight switch (Advance auto parts) and I have a 68 front end on it. Would it be something in the switch or in the harness that makes the parking lights go out when the lights are on? I want them to stay on. Thanks for your help.
Old 04-08-2016, 07:33 AM   #5
Custom/20
Custom/20's Avatar
Pretty sure it would only be the switch. Inside the switch the contact point for the park lamps are probably shorter in length like the older model year trucks so when its pulled out all the way the go back off.
I found a thread that's some help as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=428826
Old 04-08-2016, 07:58 AM   #6
c10ss69
c10ss69's Avatar
Awesome tip! That's the same harness I have so this will fix mine right up. Thanks.
Old 04-08-2016, 08:32 AM   #7
geunther
geunther's Avatar
Just a little history on park lights. They were originally intended for just that, parking. In some states it is technically illegal to drive with just the parking lights on (I called them "be cools" back in high school). They were used to let other motorists know that the vehicle was parked and not in motion.
There is your worthless tidbit for the day.
geunther is offline   Reply With Quote
Old 04-08-2016, 10:12 AM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Parking light help
Somebody replaced the head light switch with a 67. They don't work when the head lights are on.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-11-2016, 07:21 AM   #9
c10ss69
c10ss69's Avatar
Just FYI, moving the park light wire to terminal 3 in the connector took care of my issue.
