Old 04-08-2016, 12:55 PM   #1
dtkarst
I'm sure it's been asked before...
But I figured I'd ask again. Curious as to what the differences in a 61 k10 frame and a 61 c10 frame. Buying a short bed and have a 61 longbed four wheel drive all factory, and was seeing if I could bolt my 4wheel drive stuff up to that short bed frame or what it would take..always wanted a short bed four wheel drive. So if anyone knows what it'll take to put the four wheel drive stuff on the two wheel drive frame go ahead and post. Thanks
dtkarst is offline   Reply With Quote
Old 04-08-2016, 01:02 PM   #2
62 short step
62 short step's Avatar
Re: I'm sure it's been asked before...
You would be better off cutting the 4x4 frame down to a short bed. The 61 2wd frame is totally different.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 04-08-2016, 01:08 PM   #3
61K10
61K10's Avatar
the k10 frames are similar to the 64-66 and the 60-62 1 ton frames ladder type.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-08-2016, 01:11 PM   #4
Classic v6 GMC's
Classic v6 GMC's's Avatar
The c10 frame is an x-frame and the and k10 frame is ladder frame.
c10 frame has coil spring rear springs while k10 frame has leaf springs in the rear.
In my opinion you would be better off cutting the k10 frame down to a short bed.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 04-08-2016, 02:33 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
Time to get that torch out.
Old 04-08-2016, 02:40 PM   #6
Brad54
Brad54's Avatar
I just picked up a '62 K10 long-bed step-side. It's EXACTLY the truck I was looking for! Long fleet just doesn't have the right proportions.
Apparently, the factory 4x4s are pretty rare.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 04-08-2016, 04:52 PM   #7
dtkarst
Wel it would be my 61 Apache k10 that I'd be using but I'd hate to cut the frame down and whatnot. Just one of those wild ideas that I came across while looking at them
