Old 03-07-2004, 09:12 PM   #1
ChevyDude
Header clearance question?
My SWB 71' 350 V8 has 3 on the tree, which will be changed at some point to auto. The engine is out while the truck is at the paint shop. I'm cleaning re-painting and adding chrome goodies to the engine and I have a set ceramic coated headers for the truck. My question is: Will I run into any problems with the headers clearing on the drivers or linkage side? If it is a problem what can I do to make the headers fit?
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 03-07-2004, 10:32 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Are these headers for a small block automatic truck?
Old 03-07-2004, 10:58 PM   #3
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
It's not the headers you have to worry about. Its the collector pipe that needs to get around the auto tranny mount (assuming you're running dual exhaust). Shouldn't have any trouble with the headers. Well, I didn't on my 83 w/power everything & I'm running plain jane headers. If you still have the y pipe, then I have no idea. Hope this helps.
Longhorn Man:
I liked your website. Great info & presentation!
Todd
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 03-08-2004, 12:33 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
I put headers on a v-8 three on the tree, and had to modify the Z-bar. It would hit one of the tubes when you pushed the clutch in. So i cut it off and welded it on where i needed it.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 03-08-2004, 01:45 AM   #5
PhilaTruck
PhilaTruck's Avatar
I apologize in advance
Old4Chev4X4-
So I said to my wife: Whatsa Z-Bar?
She replied, "A place in France where you go for drinks."
Yet I love her anyway.
But seriously, is that a 4x4 thing? My conversion was E-Z. All I bought was extra hangers & gaskets. No weldin', no nuttin.
I do have a set of collectors that I'm told fit a 4x4, but they look the same as my 4x2 set.
-Todd
Subscribe here!
Old 03-08-2004, 02:04 AM   #6
Longhorn Man
The Z bar is the mechanical clutch linkage, where the rods have a linkage on the frame.
If you have an automatic, then you won't have the Z bar.
Old 03-08-2004, 09:22 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: I apologize in advance
-Todd
PhilaTruck, your truck is a later vintage than his. It's not the same. These earlier 3 speed trucks don't even have a crossmember under the tail end of the tranny like your truck does. The crossmember is several feet further forward, located underneath the bellhousing. The trans just hangs off of the bellhousing, out in the middle of the air.
As far as the question goes, it really depends on the header itself. I have used Hooker Comps on a small block and 3 speed and it worked well. I did have to install the header first and then slip the z bar through the header tubes afterward, but once in place, it worked perfectly.
Also, the Hooker headers nestled perfectly in underneath the crossmember without hitting anything. It was completely painless. I can only vouch for Hooker though, depending on which brand you have, your results may vary.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-08-2004, 10:53 AM   #8
cdowns
cdowns's Avatar
really depends on the brand of headers ----some fit---some don't
Old 03-08-2004, 12:17 PM   #9
PhilaTruck
PhilaTruck's Avatar
Thanks for the education-
Subscribe here!
Old 03-08-2004, 12:20 PM   #10
ChevyDude
The headers I have that are in question are the Summit brand that are repackaged DynoMax. They say the are made to fit 67-72 trucks.
Alex
Old 03-17-2004, 09:16 PM   #11
OLDCHEV4X4
OLDCHEV4X4's Avatar
The headers that gave me the problem were Blackjack headers on a 2WD 1/2 ton.
I wouldn't buy them again. They always leaked at the head no matter how many gaskets you used. I had to take them off and fly cut the sealing surface. I also had to slot some of the bolt holes at the head.
Randy
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 03-17-2004, 10:09 PM   #12
Trucks
Is that a Chevy 69...?
headers, yes no?
Is it worth it to do headers? Whats the life of them (leak free).
I suppose it depends on use, for a truck I actually drive, in any conditions I wonder if they'd rust away, I hear they leak in lotsa places before long and can't keep the bolts tight.
Maybe they are just for blacktop runnin summer trucks?
Ahhhh, the wonderful sound of a rumbling V8.
Trucks is offline   Reply With Quote
