04-07-2016, 06:33 PM | #1 |
Sputter and then Died - but starts right up
Looks like I'm not the only person having fuel troubles today...quick history.
My 350 died today in the middle of the road after a sputter for a few feet. Pulled the side of the road looked under the hood and cranked it over and started no problem; got another half mille or so before it did it again - then another 1/8 mile before it did it again before I was able to get it home. I did run out of gas last week which leads me to believe there is a partial clog somewhere or a bad fuel pump but I am a novice so I am looking here for help. What confuses me is that it starts up just fine and then dies so I want to rule out ignition/spark but someone please tell me different. Thanks as always |
04-07-2016, 06:51 PM | #2 |
It's Better With Nitro
Re: Sputter and then Died - but starts right up
Check your fuel filter. It sounds like there might be some heavy debris that is restricting enough fuel delivery under pressure/load that it starves the engine, but does not restrict flow enough when idling.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
04-07-2016, 08:44 PM | #3 |
I had a 72 Chevy truck given to me, and tried to drive it home but never made it more than a block or two and it would shut off. Fuel filter was bone dry when I'd pop the hood and check it. After throwing a couple parts at it, it turned out that the fuel tank sending unit was rusty and had pinholes that allowed it to suck in air and loose fuel.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4 |
04-07-2016, 08:46 PM | #4 | ||
04-07-2016, 10:25 PM | #5 |
If you drive it down the street and it dies, it's probably your fuel pump.
I had a fuel pump die on a road trip once... I zip-tied the secondaries closed on the 4bbl so the engine was sucking through only the forward primaries, creating enough vacuum to pull fuel through the lines past the dead fuel pump. I drove a couple hundred miles home that way. It ran lean, so it ran hot, but didn't overheat. When I'd drop the RPM below a certain point (below 50mph in 3rd gear/ 1:1), it would start to stumble and sputter because it was running out of fuel. Actually, it didn't have enough fuel to keep it running. -Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
04-08-2016, 12:11 AM | #6 |
Early mid seventies I had the use of a forestry truck that would occasionally stall out and that problem wasn't figured out until the tank was flushed. Apparently there was a piece of paper in there like from a lunch bag.
04-08-2016, 12:15 PM | #7 | |
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car) 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
04-08-2016, 12:32 PM | #8 |
Chevy addict
Yup, 9 times out of 10 it will be the rubber hoses between the fuel pump and fuel line and the rubber hose coming off the sending unit to the fuel line. Fuel filter is usually the first check.
04-09-2016, 06:56 AM | #9 | |
Can you elaborate what you mean here? You mean the rubber hoses are clogged or bad? |
04-09-2016, 12:18 PM | #10 |
One thing to check if this persists is the coil. I had this happen and it was the coil getting hot. Replaced and worked for years. Good luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-09-2016, 02:13 PM | #11 | |
Guy swore it was vapor lock. It'd die in traffic, and he'd pop the hood and wrap the fuel line and pump in a rag and dump cool water on it. After the third time when we were stuck in traffic and the thing died and he did his ritual, I said I'd buy him a new coil at the next parts store--if it fixed the problem, he'd give me my money back. I got my money back. The air through the radiator and above-idle fan speed was putting enough air over the coil that it was keeping it cool. But when he's slow down, the coil would overheat. He thought he was cooling down the fuel lines and pump, but it was really just giving the coil enough time to cool off and function again. Chrome coils are the devil... they reflect heat back into the coil. There's a reason the factory coils were black--they shed heat. -Brad
