01-31-2016, 12:00 AM | #326 |
60-66 Nut
Re: Power Brake Booster Adapter Bracket
I replied to your PM.
02-29-2016, 06:32 PM | #327 |
Moderator
I'm looking for the boot to use (dust boot) on the firewall. Would this work?:
http://www.classicparts.com/1963-72-.../#.VtTGluYYFas 63-72 Push Rod Boot
03-01-2016, 12:57 AM | #328 |
60-66 Nut
I have not tried that part, but it looks like it should work.
03-18-2016, 12:29 PM | #329 |
Captainfab,
I'm building a 65 GMC shortbed truck with my son. We are using the drive train from a 69 chevy longbed including the powersteering/steering linkage components. I'm interested in the bracket but have a few questions regarding the swap and use of your bracket. Thanks, ARG0220 |
03-18-2016, 11:55 PM | #330 | |
60-66 Nut
I'll send you a PM.
03-26-2016, 10:59 PM | #331 |
Has anyone converted to non power disc brakes? Is this a possibility?
03-26-2016, 11:49 PM | #332 |
60-66 Nut
It is done quite frequently. All you need is a manual master cylinder for disc brakes and bolt it to your firewall.
03-28-2016, 12:02 PM | #333 |
Thanks for the quick response. This is my first complete brake system install. The info is much appreciated.
04-03-2016, 10:21 AM | #334 |
Capt. will you pm payment info ?
04-03-2016, 11:35 PM | #335 |
60-66 Nut
PM sent.
04-05-2016, 10:57 PM | #336 |
I sent PayPal and pm for a bracket. Thank you !
04-05-2016, 11:13 PM | #337 |
60-66 Nut
Payment received and PM replied to.
04-09-2016, 07:25 PM | #338 |
Junior Member
captainfab, Just making sure this will work for a 68 swb 4x4 frame? It is has the flat area for the steering box. Thx!!
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
04-10-2016, 12:34 AM | #339 |
60-66 Nut
Tis is the for sale thread for the '63-'66 brake booster not the steering box adapter plate.
To answer your question, I have sold many steering box adapter plates that have been installed on K series frames. I just do not have installation instructions or a template specific to the K series frames. I can give you a link to a build thread that has all the dimensions and pictures you need.
04-10-2016, 01:03 PM | #340 |
Junior Member
My bad, i was going through so many threads about them i just replied. lol.
Yes that would be great! Thank you sir!
04-10-2016, 11:38 PM | #341 |
60-66 Nut
I posted a link in the power steering box adapter plate for sale thread.
04-12-2016, 10:18 AM | #342 |
Sent you some dough for the Booster bracket.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-12-2016, 11:57 PM | #343 |
60-66 Nut
Payment received. I should be able to ship your booster bracket on Thursday.
05-08-2016, 09:18 PM | #344 |
Captain, I need a booster bracket for 65 C10.
05-08-2016, 11:03 PM | #345 |
60-66 Nut
05-15-2016, 06:23 PM | #346 |
Do you have some adapter brackets in stock? Just trying to figure out turnaround time for one.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
05-15-2016, 10:53 PM | #347 |
60-66 Nut
I replied to your PM. Other than a couple of powder coated booster brackets in stock, most orders are built when ordered.
05-25-2016, 01:05 PM | #348 |
Where can i source the vacuum for adding a brake booster? 1965 283. There is PCV valve and fitting behind carb that has a plug on oppsite side of the valve. Can I use that plugged port for the booster vacuum source, or does it have to be isolated from the PCV?
05-25-2016, 11:41 PM | #349 |
60-66 Nut
The vacuum for the PCV should be isolated from any other vacuum operated accessory. Is there no manifold vacuum port on the carburator? If the one with the PCV is the only one, then you will have to use that. Another option is a carb spacer with a vacuum port. Of course this depends on what carb you have.
08-08-2016, 12:46 AM | #350 |
60-66 Nut
I will be on vacation from 08-08-16 thru 08-25-16. If you wish to make a purchase you can post here in this for sale thread, send me a PM or an email to captainfab454@hotmail.com. I will reply to your inquiry when I return on the 25th. I do currently have a list of orders to build and ship when I return but I will add your name to the list in order of when received. Thanks for your understanding.
