Old 04-10-2016, 12:06 PM   #1
lgvl
lgvl's Avatar
New wheel suggestions?
So after languishing in my driveway slowly rotting away the wife and I decided to take our my '82 C30 3+3 DRW to the body shop and have the small rust holes in the rocker panel replaced and a new white coat sprayed on. Since we're laying down quite a bit of money now to have this work done it seems prudent to take care of a few other issues with the truck i.e. replace the completely rotted exhaust, replace the rear tires and find some wheels that will match that nice shiny new paint job. I'd be happy to stick with the white stamped steel dually wheels it has now but I've also been looking at some aluminum ones as well. Does anyone have any experience with the Ultra 002 dually wheels? http://www.jegs.com/i/Ultra-Wheel/60...566#tabpanel-4. I'm a bit confused why there's a front and rear version, I see the offset is different but I was hoping someone could clear up why they're not reversible like the stock ones. Also from what I have read the '82s used a 8x6.5" hole pattern which is what these are, but the site doesn't say if they're hub centric wheels or not. That was a lot of typing for a simple question, sorry. Thanks guys. I will post pics when it's all done.
P.S. - If anyone has any other suggestions I'm happy to hear them.
'82 C30 3+3 Dually 454
lgvl is offline   Reply With Quote
Old 04-10-2016, 02:26 PM   #2
Malo83
Cruzzzn' Vet
Malo83's Avatar
Re: New wheel suggestions?
That rim will look killer on your truck
Malo83 is offline   Reply With Quote
Old 04-10-2016, 03:01 PM   #3
mongocanfly
mongocanfly's Avatar
Not sure why they list the offset different, my steels are the same,, on the front/back part the usually only finish one side of aluminum wheels and they would have the lug seats on that side..on the steels you have the lug plate for that..I considerd alum for mine but couldn't find any I liked so I went with similators over my white steels.
Old 04-10-2016, 04:29 PM   #4
Pontiac1976
Pontiac1976's Avatar
Because there is inner and a outer on the back. I forget now but if you look in the owner manual it will tell you what rim's can go where.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 04-10-2016, 11:26 PM   #5
lgvl
lgvl's Avatar
Thanks guys, I think they look pretty nice too and the price isn't ridiculous. My biggest worry is whether they will fit and if they are hub centric. If they're not hub centric then they're not an option.
