Old 04-10-2016, 04:40 PM   #1
muSScle
frame vin decoding
I purchased a 72 shortbed a few months ago. The seller said the cab came from a 72 c10 longed but the original short frame was from a 68. I recently had a friend over that said the frame is from a 66. The numbers located on the frame on the drivers side just pass the core support are as follows
0143169
or
O143169
I can't quite tell if the first character is a letter O or a zero. The 9 at the end I am 75% sure its a 9. If anyone could help me decode the number I would greatly appreciate it. I was just about to start ordering porter built suspension parts and if this is not a 67-72 frame, I will have to locate one before moving forward.
1972 Chevy c-10 SWB
1996 matte black impala SS
muSScle is offline   Reply With Quote
Old 04-11-2016, 10:18 AM   #2
muSScle
Re: frame vin decoding
If anyone has a link where I can decode it myself I would greatly appreciate it.
1972 Chevy c-10 SWB
Old 04-11-2016, 10:58 AM   #3
geunther
geunther's Avatar
Not a lot of decoding is possible. From memory, I don't think you can get the year of the frame from the partial VIN. You can get the plant letter code, but the numbers are just a portion of the original VIN. From yours I am assuming Oshawa plant
geunther is offline   Reply With Quote
Old 04-11-2016, 11:06 AM   #4
muSScle
Thanks geunther, I've seen posts where meters stated the number before the letter was the year but there is no number before the letter on this frame.
1972 Chevy c-10 SWB
Old 04-11-2016, 11:16 AM   #5
geunther
geunther's Avatar
Not sure about all of them, but mine appears to be like yours, it starts with the plant code (B in my case) then six numerical digits (VIN sequence number).
Old 04-11-2016, 11:39 AM   #6
muSScle
Thank you, that seems to be the case with mine. I'm curious as to if there is another way to tell. I'm planning on doing a porterbuilt suspension and I need to know going forward that my frame is a 67-72 frame.
1972 Chevy c-10 SWB
Old 04-11-2016, 12:41 PM   #7
geunther
geunther's Avatar
What was your friend's reasoning for believing it was from a 66? Can you post a picture of your rear cab mount(s). There are some slight differences that maybe we can see.
Old 04-11-2016, 01:15 PM   #8
muSScle
He mentioned that the front of the frame rails were different than that of a 67-72 frame. I'll try to figure out how to post a picture of what he was referring to. The attached photo is the frame on his 1970 c10
1972 Chevy c-10 SWB
Old 04-11-2016, 01:18 PM   #9
muSScle
This is my frame
1972 Chevy c-10 SWB
Old 04-11-2016, 01:46 PM   #10
boostedc10
boostedc10's Avatar
Your frame is a pre 67. Your friend is right, the front horns on the frame changed in 1967. Take a picture of the whole frame and I can get you closer to the year. Preferably on from a top angle.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 04-11-2016, 01:51 PM   #11
boostedc10
boostedc10's Avatar
I actually found a thread on the boards that will help you identify it. The 1960-62 were X frames.
http://67-72chevytrucks.com/vboard/s...d.php?t=325736
Brandon
Instagram: DRVFSTR
