Old 03-30-2016, 03:16 AM   #1
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
WTB 15x8 or 16X8 6 lug steelies with 4 nubs
looking for a set of 4 or 5
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 03-30-2016, 11:39 AM   #2
paul mora
Re: WTB 15x8 or 16X8 6 lug steelies with 4 nubs
My son may have a set of 4 15 in we pulled of his truck yesterday in So Cal. He is going back home tomorrow to Santa Cruz. Pm me with a text or tel number and I will have him contact you about the wheels. There may be a picture of the wheels in the build section for 67-72 trucks under the name "werker"
Pulatoy
paul mora is offline   Reply With Quote
Old 03-30-2016, 11:51 AM   #3
craneboy72
craneboy72's Avatar
Not mine but I saw a set of 15" x 8" six lug on craigslist NH. Might be a little pricy shipping but not a bad price on rims and tires.
https://nh.craigslist.org/wto/5512787734.html
craneboy72 is offline   Reply With Quote
Old 03-30-2016, 02:46 PM   #4
72K5CSTDarkOlive
sorry not 16x8. factory 16x5
Old 03-30-2016, 03:08 PM   #5
396ci
396ci's Avatar
i have some 15x8 but not what your looking for. bump for you.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 04-11-2016, 09:43 AM   #6
wannabefastcrf
Is This what your looking for? These are 15x8. I have 4 of them.
wannabefastcrf is offline   Reply With Quote
Old 04-11-2016, 02:15 PM   #7
72K5CSTDarkOlive
Yes, but what is the backspacing on these?
Old 04-11-2016, 07:13 PM   #8
wannabefastcrf
About 4" backspace
Old 04-11-2016, 07:27 PM   #9
396ci
396ci's Avatar
could you clarify what your looking for? b/c i have a set of 15x8 4 nub wheels and im local. thanks
Brian
XNGH ECV Chapter 58
Old 04-11-2016, 11:28 PM   #10
72K5CSTDarkOlive
You bet. I recently picked up a set of 5, 15x6 4 num wheels. 3 of the 5 have different backspacing than the other two.
The goal I'm trying to achieve is finding a set of 15X8 and making them into a 16x8 wheel. What I learned about the different backspacing in the set of 15X6 that I have is that the set of 3 have a backspacing just a shade above 3.5 measuring flush from center (where the lug nut sits) and another measurment on the inside lip of the center where you slide the wheel over the hub. There is about 1/8" difference (maybe less) However, doing the same measurement on the other two (just to make apples to apples comparison) there is a significant difference. From the center (flush on the lug nut) measures at 4.25" and the edge of the inside center lip measures at 4"...
I made the two different measurements because I noticed on yours, you measured on the center cap lip.
The first two pics are the 15x6 with the 3.5"-3.7 backspacing. (again depending on where you measure from)
Name:  3.5 from center.jpg
Name:  3.5 from center lip.jpg
This next two pics is the 15x6 with the 4"-4.25" (again depending on where you measure from)
Name:  4.25 from center.jpg
Name:  4 inch from lip.jpg
This is a pic of the 15x6 with the 3.5"-3.7 backspacing moutning on the hub. This backspacing clears disc brakes and oversize rotors.
Name:  wheel clearing hub.jpg
This pic is the other 15x6 with the 4"-4.25". You will notice this wont clear disc brakes and it also rubs the steering rod ball joint.
Old 04-11-2016, 11:31 PM   #11
72K5CSTDarkOlive
damn pics turned upside down.. but I think you can tell
This pic is the other 15x6 with the 4"-4.25". You will notice this won’t clear disc brakes and it also rubs the steering rod ball joint.
Name:  wheel hitting brake.jpg
I'm looking for a set of 15x8 that have the backspacing of the 3 that I have which is about 3.5-3.6 or maybe 3.75..
If I cant find a set of 15x8 with the backspacing I need then I will just use what I have and make the 15x6 into 15x8 using the same back spacing.
Hope that helps
Old 04-12-2016, 05:57 PM   #12
396ci
396ci's Avatar
i can check the back space but im pretty sure mine are 4".
Brian
XNGH ECV Chapter 58
Old 04-12-2016, 06:01 PM   #13
1968vetL-71
Junior Member
1968vetL-71's Avatar
Wannab..... I don't want to hijack his thread but if he passes i might be interested pending price? Thx
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 04-24-2016, 11:48 PM   #14
396ci
396ci's Avatar
Hope that helps
Mine are 3 7/8" back space.
Brian
XNGH ECV Chapter 58
Old 04-25-2016, 12:39 AM   #15
cheyenne shortstep
cheyenne shortstep's Avatar
The 15x6 with less back space are probably Blazer/4x4 wheels and are worth more than 2wd. They will clear most disc brake conversions making them desirable to those wanting to go disc and retain steelies. In one of your pics it looks like you have at least one. They are easily identified by the deep center.
cheyenne shortstep is offline   Reply With Quote
