Old 04-11-2016, 04:38 PM   #1
weldvair@embarqmail.
dropped spindles help
I have a 1968 c10 that has disc brakes in the front. I want to install dropped spindles but, do not know what year spindles to order. I
do not know what the previous owner used for upper & lower A arms
to use disc brakes.
any help would be appreciated.
Don
weldvair@embarqmail. is offline   Reply With Quote
Old 04-11-2016, 07:05 PM   #2
Mike harris
Re: dropped spindles help
Have they definitely changed the control arms? I am unsure on what year trucks the spindles are off but summit sell a few spindles specifically for disc brakes on 67-72 trucks. bought mine off eBay and they bolted straight up to the original arms.
Mike harris is offline   Reply With Quote
Old 04-11-2016, 07:25 PM   #3
Mike C
Mike C's Avatar
If it was done correctly, they changed to the disc spindle ball joint. I would buy the spindles you want and just buy the correct ball joints and that should fix any incompatiblity issues.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-11-2016, 08:10 PM   #4
Shady Rascal
Shady Rascal's Avatar
There are also concerns about the steering too. The tie rod ends aren't the same. No big deal, just saying it's more than swapping four ball joints.
Shady Rascal is offline   Reply With Quote
Old 04-11-2016, 08:39 PM   #5
snipescastle2
snipescastle2's Avatar
Talking Re: dropped spindles help
I too, found that the tie rod ends can be different. I used the correct ball joints and tie rods and still had to trim some metal off the very end of my lower control arms,not much at all, but still had to do it(it was rubbing the inside of my stock 15" rally wheels) The '71-'72 lower control arms have a different bump stop bracket than the 67 to 70 models do also.
Good luck with your drop setup!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 04-12-2016, 09:19 PM   #6
Mike C
Mike C's Avatar
Correct. Thanks for adding that in as I forgot to include that.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 04-14-2016, 01:36 PM   #7
MrBlue
MrBlue's Avatar
Gents, Those that have the dropped spindles, how much did the relationship of the lower ball joint to rotor move up? I know it should be simple, use 2-inch drop spindles and the rotor moves up 2-inches, but just want to make sure.
I would need to replace the current wheel to use drop spindles and want to make sure I am thinking correctly.
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 04-14-2016, 04:55 PM   #8
thanks guys but, how can you tell early A arms from the latter style?
Don
Old 04-14-2016, 05:57 PM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
Don
Can you post pics of your suspension?
I remember going back and forth with a member to find out he actually had drop spindles already.
Pics of your spindles and a-arms would be a big help.
Keith
Convert to disc brakes.
Old 04-15-2016, 11:26 PM   #10
rotten67
I hated my mine they are wider and made tires rub fender. I took them off.
rotten67 is offline   Reply With Quote
Old 04-16-2016, 10:42 PM   #11
powell72
powell72's Avatar
If the spindles are for 70 and older, your tie rod ends will be 5/8" with left hand threads, a true 71/72 spindle uses 11/16 right hand thread tie rods.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
