Re: Project U S Army Sargent Slam
Temperary ignition switch panel is in. Just have to clean up the wiring and put it in some plastic wire loom.
Having a hard time with the size fitting on the pressure line of the power steering. Thats the only thing left and its ready to fire In the truck for the first time.
Installed the temperary exhaust
Needed the get the exhaust tight above the bottom of the frame so it doesn't scrape. Also went with Flowmaster hp2s
Got the pressure side power steering line figured out. It ended up being a 11/16 Fitting going into the power steering gear box. I installed a shut off valve. Thank God I did. I tried to start it and I end up having a short in the ignition toggle flip switch. Causing a small electrical fire. That quickly went out because of the shut off switch. It could have been a lot worse. I only have to replace about 4 wires at eight feet each and a toggle switch
#6 | |
![]() got a linky for that gas pedal???
My Build: 57 Chevy Pro-Street Last edited by ptc; 04-15-2016 at 12:07 PM. |
Got the S10 steering column in today. I used a 2 1/2 exhaust clamp and ovaled out the holes were the factory steering wheel clamp mounted under the dash.Then I drilled a 2 1/2 inch hole on the floor board with a hole saw to get the column to the engine bay. Tomorrow I Will put in the S10 brake booster.
