Old 03-07-2004, 07:49 PM   #1
ScottH
ScottH's Avatar
Need help in removing 72 inner grill
Can anyone tell me how to remove the inner grill on a 72? I've removed all bolts but the plastic "nuts" they screw into don't want to come out. Also if I should break a couple are they available after market?
Any info is appreciated.
Thanks.
ScottH is offline   Reply With Quote
Old 03-07-2004, 08:21 PM   #2
JimKshortstep4x4
Talking
Most of the time they will pop out if you use a door panel tool to remove them. The parts are available as a set. I bought a set from Christian's Truck parts but I am sure most every vendor has them.
Jim
Old 03-07-2004, 10:56 PM   #3
ScottH
ScottH's Avatar
Jim, thanks for the info. Can u tell me if you pry them from the larger side that the screw head is on, or push from the smaller side?
Thanks.
Scott
Old 03-08-2004, 12:29 AM   #4
bpmcgee
bpmcgee's Avatar
When I pulled my grill I had to pull them out with pliers.
Brian
bpmcgee is offline   Reply With Quote
Old 03-08-2004, 09:31 AM   #5
JimKshortstep4x4
Talking
I pry between the plastic grill and the aluminum shell. Sometimes the can be a pain!
Jim
