WTB: Power Steering Pulley 3993325DJ
Looking for a clean, straight, power steering pulley. Must be 3993325DJ (stamped on front). As far as I can tell, these came at least on some 4x4 trucks in '72 (maybe other years, maybe other applications).
Surface rust is okay; major pitting, any wobble, or belt surface irregularity isn't. These bend easy, so if you have a straight one on a pump that you want to sell, remove carefully! ![]()
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
![]() Join Date: May 2005
Re: WTB: Power Steering Pulley 3993325DJ
Got complete pump minus line fitting with bracket. Will look at conditio for you
Mostly interested in just the pulley... unless the price is right! Let me know, photos would be great. And I definitely need that pulley number.
Bump.
Here you go, looks to be in good, usable condition. $35 shipped.
That might work. Have you spun it on a pump, to see if it is straight? I've never been able to tell if they're true by just putting them on a flat surface.
Ok I just put this pulley on a pump and spun it with a 1/2" impact and it spins true.
That's good news!
Last question: hard to tell from the photo - is the rust in the belt groove area surface rust or pitted? Can I clean this pulley up with a wire wheel and expect smooth metal, or will I be left with a clean but pitted belt track? If it's surface enough to leave a smooth belt groove, I'll take it. But I don't want to just swap my bent pulley for a straight one that will wear belts out quickly with a rough groove. Thanks!
I would sand/beadblast it myself but to be honest it doesn't look too bad in the groove and should clean up fine with a wire wheel.
Sorry for the delay, crazy busy day at work today. Okay, I'll take it. PM me payment info? Thanks!
