Old 02-28-2016, 06:44 PM   #26
dracko
dracko's Avatar
Re: Where to start on this blasted cab?
The bracing isn't hard to work around.
I used those panels from classic parts and they fit perfect. I was in shock at how well all the bends lined up. (The holes didn't line up at the bottom of the pillar but that's easy to work with)
They should be all you need for floor and inner rocker.
dracko is offline   Reply With Quote
Old 02-29-2016, 12:16 AM   #27
60chevyjim
60chevyjim's Avatar
Originally Posted by msg View Post
Capt, I just realized those rockers appear to be the inner ones that I bought many years ago. Maybe Im better off buying the part you described with the outer floor and inner rocker combined? I have not found it yet, best Ive found is this outer floor.
http://www.classicparts.com/1960-66-.../#.VtNNkpMrLsE
this part above is the inner rocker and outer floor that you need.
the picture of the outer rockers you bought are slip on rockers .
I would recommend getting a pair of full factory style outer rockers .
the slip on ones don't repair all the rust that your outer rockers have in your pictures.
60chevyjim is offline   Reply With Quote
Old 02-29-2016, 01:41 AM   #28
Brad54
Brad54's Avatar
I noticed on those floor pans you have, that the bottom part of the toe board/firewall is part of the replacement pan. On the actual truck, they are two separate panels, joined along a down-standing flange on each.
I cut away the toe-board portion from the pan, and created the downstanding flange along the front of the floor pan and installed it as per original.
Here's the article on how I did it.
-Brad
http://www.hotrod.com/how-to/interio...floor-install/
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 02-29-2016, 10:46 AM   #29
msg
Thanks guys! I'll reorder the right inner rockers and while Im at it. It looks like the inner wall where it meets the floor will need replacement too.
I assume this is the right part for that. Different suppliers call it different things
http://www.classicparts.com/1960-66-.../#.VtRS5ZMrLsE
http://www.topbananaparts.com/driver...ot-well-1.html
Is this the right order to make repairs?
  1. First start by bracing if possible
  2. Then hanging the doors
  3. work on one side at a time
  4. remove the rocker on one side
  5. Fit the rocker patch panel while checking it against the closed door for gap check
  6. Weld the rocker in place
  7. On that same side cut out and replace the cab corner
  8. Cut the front floor bad section out (only bad metal)
  9. Cut the inner cowl wall or what ever this is called http://www.classicparts.com/1960-66-.../#.VtRS5ZMrLsE
  10. Weld in that part
  11. Then weld in the front floor (with the aid of Brads article)
  12. Make the cut on the rear floor section (using the tap screw and cut to fit method) and remove inner rocker as well.
  13. Weld in the inner rocker
  14. Weld in the rear floor
  15. Then make fixes where ever I can with my fab skills where there are no patch panels for spots like where the upper floor meets the floor pan and the transmission hump
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 03-03-2016, 02:42 PM   #30
msg
Originally Posted by Captainfab View Post
At a minimum you are going to need cab corners, outer rockers and inner rockers and outer floor. I would get the one piece outer floor with the inner rocker. Those are much easier to work with and get things straight IMO. Some of the back of the cab you will either need to fab yourself or find a donor cab to cut that section from.
Capt, is this the outer with the inner rocker you mentioned?
http://www.classicparts.com/1960-66-...tinfo/45-934/#
I'm having trouble understanding how the inner and outer rocker assemble to the inner floor.
If I were to get the part above, would I not then need this inner rocker?
http://www.classicparts.com/1960-72-.../#.VtiFgpMrLsE
Old 03-03-2016, 04:10 PM   #31
dracko
dracko's Avatar
This is that outer floor/inner rocker panel welded in.
The outer rocker spot welds to this outer floor, overlaps it by about an inch.
Old 03-03-2016, 04:26 PM   #32
msg
Thanks Dracko! so for the repairs I wouldnt need the inner rocker if I use that full outer cab floor piece you show in the 1st pic? Just that part and the full rocker? Looking to get an order in soon and wanted to get it right.
Old 03-03-2016, 05:08 PM   #33
dracko
dracko's Avatar
Ya man, just need that one in your first link ($65) and outer rockers.
Lower A pillars and kick panels too I'm guessing.
Old 04-14-2016, 09:09 PM   #34
msg
Finally getting back to things, and have a few part questions.
I might need a different thread on this but thought to start here.
What bolts do I need to mount the pillars back once I get the old rusted ones off? And if anyone has tips on removing/cutting off these bolts please mention.
Also the floor currently has a washer/disc to mount the cab to frame. The patch panel has a recessed spot but no disc. Is there a part I need to order, or is this disc able to be ground off at spot welds and reused?
And then there was this, the door hinge mounting plate came out from the inside of the rusted out lower inner cowl panel. What needs to happen to replace it?
Old 04-14-2016, 09:54 PM   #35
craiginaustin
craiginaustin's Avatar
Your level of rust looks more or less like mine at first glance. Following along with great interest!
1964 C10 Fleetside Long Bed
craiginaustin is offline   Reply With Quote
Old 04-14-2016, 10:21 PM   #36
djones1a
You need a small sand blaster to clean up the rust that was underneath the metal you removed before installing the new metal,make sure to use weld through primer on the back sides and insides of the new metal before you weld it. I hope you did not strip the rest of the hood with paint stripper,the proper way would be to use a mud hog with 80 grit to buzz it off.
djones1a is offline   Reply With Quote
Old 04-15-2016, 12:12 PM   #37
61K10
61K10's Avatar
I replaced my rockers both inner and outer on both sides. I did one side at a time with the cab bolted on the frame. No bracing was added and nothing moved. I took a bunch of measurements of the door openings before i did the rockers. Might have got lucky? Now off the frame on a cart would be different.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
