Smog Pump on 68's?
Would a 68 have had the smog pump and related plumbing in the exhaust manifolds and such? If so anyone have any good pics of this set-up? 307 V8 by the way.
Thanks, Dave. |
Re: Smog Pump on 68's?
I don't hink so as they were a few years later in mid to late 70's
![]() Join Date: Dec 2009
dont know about trucks but I do know that A.I.R. systems were installed on cars in California since 66. Kinda rare if you can find them complete too.
My 68 396 had an air pump on it, the under hood decal was still somewhat intact when I bought the pickup in 1980, not now though.
The air pump and associated parts were long gone when I bought it. Not sure when and why air pumps wee installed on pickups...have not seen many pre 72's with them, though... |
![]() Join Date: Dec 2006
Don't know about your state and 1969 might have been different anyway but the 1/2 ton trucks in Calif. had pumps but the 3/4 ton did not have anything other than PVC.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
Thanks guys, looks like mine had the stuff at one time. I found a 72 locally which has all of it so perhaps I'll grab it just to save it for the future...
![]() Join Date: Feb 2002
Yes. California vehicles had the A.I.R. smog pump system for mdl.yr. 1968. My '68 C/10 Stepside with L6 292 had a smog pump and connecting lines into the cylinder head.
I have deleted the AIR stuff and used brass plugs to fill the AIR holes in the head. Truck was Fremont built, and originally sold in L.A. I guess on the V8s, the AIR inputs were in the exhaust manifolds. I would advise you against re-installing an AIR system. They didn't do much for air quality in reality, and were a big performance drain, and also prone to manifold leaks. Mostly a political solution. A well-tuned engine will pass emissions without the AIR installed. Most states don't even smog test vehicles this old. Arizona does, but they don't check to see if I still have obsolete gear under the hood.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 04-15-2016 at 07:24 PM. |
My brothers all original 69 C20 with 350 had a smog pump. SPID showed CA emission so it was from the factory.
![]() ![]() Join Date: Sep 2008
My dad bought a 68 new here in Arkansas, and it had a smog pump.
He went back and traded for a new 69 and it did not have a smog pump.
#10 | |
![]() Join Date: May 2010
In response to the OP's original question. The 68 service manual has a section (6T) devoted to the Air Injection Reactor. It shows both I6 and V8 applications but does not state when it was required. Last edited by FirstOwner69; 04-15-2016 at 11:11 PM. |
#11 | |
Does your SPID show emission line item? |
Here's why I was asking--I think the truck is a 71.
My brothers truck was purchased in Newhall, CA. Next time I go over Ill take a look at the door tag to see the production date and see what the dealer plate frame is.
#15 |
What in that picture makes you think 1971? The installation picture in the 1968 service manual looks just like that. Here's a link to a thread with links to the manuals. Look at section 6T.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016 |
#16 |
#17 |
#18 |
#19 |
No air pumps in California cars in 66?Hmm?
| Bookmarks |
