Old 04-15-2016, 11:42 PM   #1
1972BlueC20
1972BlueC20's Avatar
Rag joint help
I am installing a CPP 50014 power steering box on my 72 c20 that originally had manual steering. I ordered a original rag joint that would of fit a 72 with factory power steering. The rag joint seems too big. I tightened the part that goes onto the steering box splines as tight as I can get it with hand tools and it's still too big. It doesn't even grab onto the CPP shaft. It just falls off.
Anyone know what rag joint I need for the CPP box?
Also, on rag joints in general are they just hand tightened on the spline shaft or are you supposed to use power tools and is that maybe why it seems too big because I need to really bare down on it to make it tight on the shaft?
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 04-15-2016, 11:50 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rag joint help
There are two different sizes of splined shafts on the steering boxes. I don't know which one CPP uses but it sounds like you have a box with the small splined shaft and a rag joint for the large splined shaft.
I just tighten mine with hand tools.
LockDoc
Leon
Old 04-15-2016, 11:53 PM   #3
Boog
laying low
Boog's Avatar
Re: Rag joint help
That's it. I had to switch mine out also. I picked mine up at O'Reillys next day.
Boog
Old 04-15-2016, 11:53 PM   #4
1972BlueC20
Re: Rag joint help
Yeah I think I need a 3/4" 30 spline with flat rag joint. Was hoping to source one locally so I can finish my conversion this weekend. I don't know if the local parts house will carry this sort of thing.
Old 04-15-2016, 11:54 PM   #5
1972BlueC20
Re: Rag joint help
Are you using the CPP box as well?
Old 04-16-2016, 07:13 AM   #6
cdowns
cdowns's Avatar
Re: Rag joint help
local auto parts store help section has everything you need in one stop no shipping required
Old 04-16-2016, 07:42 AM   #7
Boog
laying low
Boog's Avatar
Re: Rag joint help
No, I bought a reman'd sector from O'Reillys but I went from a '71 to a '76 year sector which has a faster ratio. The input shaft is smaller.
Boog
