Water Pump Pulley Help Please
On our 86-91 BBC trucks the alternator belt is a serpentine belt. I was wondering if anyone has the part numbers for the water pump pulley that also has the single v-belt groove as well? Im trying to convert my Pro-Street BBC over to this to ease my charging issue. Pic of setup For reference..
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
Re: Water Pump Pulley Help Please
Your is mostly like a 7 in pulley water pump. 69-72 there to ID: #'s BB 7" 33956666 ID: #'s SB 7" 330556 single grove.
V8 73-77 single grove water pump 7" ID:# 14023154 CC hope this helps
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
I have the later model long nose pump and currently have a double groove v-belt pulley. What I'm wanting to do is keep the double groove but make the alternator a serpantine belt like the 86-91 motors have. If that makes sense.
This is a pic of my setup but it has a cs130 amp now and has been rewired.
Ok so you have serpentine belt. on the out side, but you have a two belt pulley on the water.
If I got this right now. You want a serpentine belt on the out side of the water pump pulley and a in side V belt. Wright Then you are looking for the 84-86 Firebirds / Camaro could be the V6 305-350 set up. I got one of these for my 76 Lemans . NOT Know the #'s on them of hand not sure where I put it to look at them. Think the Monto Carlo had this set up to but can't remember what year and what motor set up.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 04-15-2016 at 11:31 PM. |
LINK: https://marchperformance.com/aluminu...mp-pulley.html
This might be the one your looking for?
#7 | |
#8 | |
Try to look in the scrap yards junk yards for the 84-86 Firebirds / Camaro could be the V6 305-350 they have the set like this if you find one grab alt or ( just the alt Pulley ) if you have a Batt impact gun, water pump pulley, belt or mark down the size, keep eye on e-Bay for them.
